Question about Sony Ericsson HPM-70 Consumer Headphones
Left side of my headphone is not working
The headphones i have are a sony ericsson HPM-70, basically the left headdphone works but you can hear it faintly compared to the right were it working fine. i simply want to know if i can fix this dilema or will i have to settle with new ones, if so what headphones would you recomend
  • Sony Ericsson Master
  • 19,396 Answers
That often happens because of a contact on the headphone wiring, The only way to fix it is by taking apart headphones, testing the wire, and checking the headphones solder joints on the speakers and on jack connector, that usually are responsible for this kind of problems.
Posted on May 05, 2009
    President:
  • 1,489 Answers
Sounds like a dirty plug or a broken wire in the cord. Yes, it can be fixed.
    Problem Solver:
  • 5 Answers
Halpe me cdma haier c1000 re sat code
Posted on May 06, 2009
    New Friend:
The left side is more problematic, since the circuitry and most of the wiring is there. It is a job to get into, and this is only for people who are comfortable with a multimeter and either very strong glasses or a loupe.
You have to carefully saw the plastic all the way around the seam - this seam is about 1/4" from the ear-pads. Use as thin a cutting blade as you can find. Saw until you hit metal, all the way around, then pry the end off.
Remove the white plastic foam inserts, and you will see three very small torcs screws with T8 heads. Once loose, you can pull the silver part off.
From there you can do some continuity checking. In my case, one of the headphone wires was touching another component on the circuit board, and bending it away from that was enough to restore sound to the left side.
Putting it back together: well, it will not be a pretty as it was. You have to line up the on-off slide with the switch, but then the silver side goes on quite easily. Do not over-tighten the tiny T8 screws.
You can use gel-superglue to put the ring/ear cushions back, but do not add glue until the ring is almost in place. You may find that you have to do some gluing of the ear pads afterwards. I suppose some black electrical tape might cover the scar you'll have from sawing, but if you find the problem, that might be an acceptable price. It was for me.
Best of luck
Posted on Mar 05, 2013
SOURCE:
I can hear only from right headphone of my sony bluetooth
Either the left headphone is shot or the headphone jack is messed up. Try a different set of head phones if its same result see about replacing the jack.
Jan 23, 2014 | Sony Walkman Audio Players & Recorders
Brokened hpm85
Hi Mr Pujari
Contact here for Service or Replacement:
Mobile Technology * pd_icon_blank.gif pd_icon_blank.gif pd_icon_servicepoint.gif pd_icon_blank.gif pd_icon_blank.gif 1785,Bld no 45,Sangmitra Nagar, Opp YMCA, D. N. Nagar, Andheri (W)
400053 Mumbai
Phone: 26713893 / 9819412373 / 9833585472
Hope this info helpful for you
May 31, 2009 | Sony Ericsson HPM-85 Consumer Headphones
Sanyo shpx310 Retractable Headphones
push the end of the headphone jack into the little white circle near on the left headphone where it retracts.
Apr 09, 2009 | Sony Ericsson Audio Players & Recorders
Sony HPM-70 not working with music feature on phone
I got a "failed" when I tried to listen to my playlist, on the first song. I switched to a different song lower down the list, and then it worked. Not sure what made the difference.
Feb 06, 2009 | Sony HPM-70 Headset
Volume in both the ear phones (l & R) is not same for HPM-85
Well u cud go to ur volume control settings or windows media player and check if they r all balanced(u will know what i mean wen u gt there).The cursor shud be in the middle of the whole bar.............Thats all i gt...gud luck. I cant gaurantee that this will work but i am always happy to offer sum small help. :}
And if evrytin is hopelesss........man this might be way off.............but ur ears may be a little less sensitive.try checking the right side wit ur left ear and the same 4 the other........XD.....sorry if i kind of spoooked u.
Dec 27, 2008 | Sony Ericsson HPM-85 Consumer Headphones
Sony ericcson head phones
sony ericsson's should just have a 3.5 headphone jack insted of the dodgy plug they have now.
Jun 30, 2008 | Sony Ericsson HPM-70 Consumer Headphones
SONY ERICSSON HPM-85
i have a w595 and hpm 85, its connection is loose when i connect it if the port moves the handsfree logo dissapears
Jun 17, 2008 | Sony Ericsson HPM-85 Consumer Headphones
K750i low volume in the playback ,please give me a solution
Well... The speaker is ok and if you're using the headset it should be loud enough for you. If you want it to be louder just use earphones/headphones that are sound isolating to block out ambiant noise. The hpm-70 can kinda do that because they go in in your as opposed to sitting on the outside of your ear. The earpiece volume is really loud. I found it hard to hear to people in some places.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Jan 15, 2008 | Sony Ericsson K750i Cellular Phone
Sony Ericsson HPM-70 Consumer Headphones Logo
10,822 people viewed this question
Top Sony Ericsson Audio Players & Recorders Experts
Greg P
Greg P
Don A
Don A
Are you a Sony Ericsson Audio Player and Recorder Expert? Answer questions, earn points and help others
