Question about Moen Plumbing
Low hot water pressure
I have a single lever Moen cartridge faucet in my guest shower. The house is 4 years old and I replaced the cartridge about 18 months ago. The water pressure and temperature has worked fine until this week when I noticed I couldn't get warm water unless I turned the handle 75%. At this point the water was tepid and would only get warm if I turned a little more, at which point the pressure would fall 70-80%. Any thoughts on what the problem might be and how to fix it?
  • jim_bates May 06, 2009
    Thanks, but I don't think that's the problem. The hot water in the sink of that bathroom is fine (heatwise and pressurewise) and I don't have any problems with heat/pressure in the other bathroom served by the same waterheater.
    New Friend:
  • 92 Answers
It sounds like you need to up the temp on your water heater so that you are mixing more cold with the hot .be careful hot water can cause burns if valve is 4 years old then it has a limit stop do not set above 120 *you will need allen key and thermometer to check temp
Posted on May 06, 2009
SOURCE:
My shower makes a very annoying whistling sound. What's causing this?
you cannot use any other cartridge posi temp only. remove flow restrictor in hand held
Nov 25, 2012 | Moen Posi-Temp Single HandleTub And Shower...
Low hot water pressure on Moen Single-Handle Shower Only posi-temp shower control. Cold water pressure is fine. Hot water pressure elsewhere in house is ok. Cold it be the cartrige -- lime buidlup, etc.?
I think you are on the right track. The first thing I would do is change the cartridge. While you have the valve apart examine the inlet ports as good as you can to see if there is any mineral buildup. You can use a short length of a small gauge mallable wire to run into water ports to se if you can break anything loose. Another thing you can do is to turn supply stop on slightly while you have the valve disassembled to wash any particles out. Hope this helps you and thanks.
May 14, 2011 | Moen Posi-Temp Single HandleTub And Shower...
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
I have a single handle Moen shower faucet. Pull to turn on. Turn clockwise for cold. Turn counterclockwise for hot. It does not leak but it is hard as hell to pull out when I turn it on. The house was...
If it is hard to pull out or push in the valve then you will need to replace it. On moen valves you can not rebuild the cartridge you can only replace them. A new cartridge will cost you around 15 to 20 dollars.
Also I would tack the cartridge with you when you gao and buy it because they make 2 different ones.
Good Luck and please rate 4 thumbs up for the free answer
Sep 21, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Moen L3175 faucet with low water pressure
IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
234 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Thomas F. Schneider
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
