Belinea 1930 S1 Monitor Logo
Alexander Yalnuzov Posted on Nov 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to switch from analog to digital mode - Belinea 1930 S1 Monitor
Jiri Sluka
Level 2:
Welcome Back:
Visited the website for 2 consecutive days.
  • Expert 20 Answers
  • Posted on Nov 19, 2013
Jiri Sluka
Expert
Level 2:
Welcome Back:
Answers
20
Questions
0
Helped
7238
Points
108
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
What's the difference between digital switches and analog switches?
Basically, the exchange of digital and analog Huawei switch mode, there is a difference between digital switch USES time-division switching, analog switch is the interchange of air separation.That is to say, the way of digital switches is non-blocking switching, analog switches have rope limit of the road.
The LED LCD TV's came out in 2009. It already has a built in digital HD tuner.
Allen wants to know how to switch the TV between the built in analog tuner and built in digital tuner.
Switching between the two tuners is done by means of the "TV mode" switch on the remote control.
You will NOT be able to select analog channels if have NOT done analog tunning.
If you need to do a retuning then hit the "menu" button select "setup" then "plug and play" enter the default pin number 0000. When you are selecting the channel source to memorize make sure you select "digital and analog". This will then cause the TV to tune and memorize both the analog and digital channels.
For details refer to page 8 of the user manual.
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Motorola cell phone W385. Display shows in analog mode. Can't find how to switch back to digital mode.
This is not a computer or a audio system to work in analog/digital mode. If you don't have image, what is most probably, you should have a flat problem, which is much common for this model. Get a new flat and change it.
May 15, 2011 • Cell Phones
Can't get monitor out of energy save mode
you talk about a dell monitor but categorised under LG monitor... if it's a Dell monitor, and its recent, it's possible you've put it in analog/digital mode when you need the other mode. push the left button on te front of your screen that should switch your screen from digital to analog or vice versa
Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
1helpful
LG Flatron W2252TQ 22'' monitor not working in digital mode
try to set your screen resolution to maximum using Display Settings in windows. Besides, are all software drivers for this monitor loaded and properly installed? Right click My Computer=>Properties. select hardware => device manager. Make sure video icons are not marked with question marks. if they are, install monitor drivers shipped with your monitor.
regards!
Marantz sr5001 has pcm light flashing after child pushed buttons on front of receiver. no longer getting audio/video in tv mode but other modes are still working without issue. how can I get audio/video...
I suppose pcm light means that the pcm mode is turned on (pcm meaning pulse code modulation), in other words, the unit was switched to digital signal, so if the digital rca or optical TV input on your reciever is not connected to anything, then you're not getting any signal into the reciever in digital mode. You probably just need to switch the unit back to analog mode (see if there is a button that says something like digital/analog, pcm/analog, optical/coax or similar, try pressing it, see if there is any change).
I might just be totally wrong on this, however, probably the best way to learn what happened is to read the user manual if you do have it (see what the pcm light signals for and check any chapters inside the manual related to that topic).
good luck
3rq8 (Triarcuate)
Denon AVR-1403 receiver switched from digital to analogue.
There are three modes (Auto, DTM, and PCM) on the input mode switch, on the main unit, selected by repeatedly pressing the input mode switch.
However, if you have already depressed the Analog button in, on the main unit you have predetermined the mode as analog.
On the remote, the INPUT MODE switch combines toggles for 5 choices, [Auto, PCM, DTS, Analog,
Ext. input]
My guess is that either the input mode switch on the main unit and/or the remote are toggled to analog.
2helpful
Can't get out of digital mode back into analog
My TV just did the same thing.  All you have to do is turn off the tv, unhook your cable antenna, then restart the tv with the antenna unplugged.  Then go to tv menu, and this time turn the digital scan off.  I really hoped this helped someone!
Top Belinea Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Belinea Computer and Internet Expert? Answer questions, earn points and help others
