LG LSC183VMA Split System Air Conditioner Logo
A
Anonymous Posted on Nov 18, 2013
Lg mco7ahr code ch 32 - LG LSC183VMA Split System Air Conditioner
Foutcode ch 24 bij LG airco
Question edited for clarity and translated to English.
A CH 24 error code indicates a pressure switch error. To Resolve: Make sure the air filter in the unit is clean. Remove any items or reposition the unit so that the air flow is not obstructed.
Apr 25, 2023
LG Dehumidifier - Error Code List ' LG USA Support
2answers
I have an error code on my LG a refrigerator that says CH E. I was wondering if this a costly repair
wow, we finally get the sorry long.
we now learn it was bad repair job.
parts and labor cost very all over earth, vastly
and so does what is wrong.
only knowing what is wrong matters. costs are estimated last, not first ever on any complex machine.
talk to the last guy that damaged the loop..
good luck with that refer.
How to fix error code CH 16 in LG AC?
It is a reminder to clean the filter
Split System Air Conditioner Considering this, what does Ch mean on LG air conditioner? It is not a problem but it is just the reminder to clean the filter of the air conditioner. ... LG Split System Air Conditioner Error code = 05 LG AC Fault Definition = Communication(Indoor Outdoor) - Communication Issue. Indoor Status = Off.
May 17, 2020
LG nini split MFL69491102 showing code CH 10
The CH01 era code would indicate a indoor sensor Fault
What could be the problem with a split 1hp lg inverter ac coming up with error code CH 32 after working for 2 to 3hours
32 is a high temp limit on the condenser. this means your system is overheating. possibly overcharged, dirty coil or fan not functioning properly
1helpful
2answers
LG Aircondioner error code CH 38
Error Code 38 on my LG Split Air Conditioner.
I call LG Mexico and they told me a Gas Leak.
Called in the Gas Guy, filled with new Gas and fixed the leak, now the AC works again. Nice.
2helpful
CH-10 error code in LG a/c.Modal-LBUC609RSA5
RAC Product: Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Multi Fdx & Multi V text 8
I have an LG mini split system, when I turn the unit on with the remote a code flashes on the wall unit 32 CH
do you have the owners manual? this is a fault code never worked on an LG mostly fujistu samsung
2answers
Lg error code ch03
Hi sir
LG Package unit LKC3009C04 comming CH 03
LP - 60
HP - 280
Both circuit
One fan motor not good
What problem
2helpful
3answers
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
