Question about LG LDF8812 Stainless Steel Built-in Dishwasher
Where do i find a model number on a LG dishwasher?
I would like procedure to remove the base of LG dishwasher LD1452MFEN2 to enable replacement of drain pump? help please
Search for LG DISHWASHER SERVICE MANUAL on Google with the model number. It is a complete guide to replace the parts. Removing the pump is half a day work!
Sep 07, 2017 | LG Dishwashers
LG dishwasher ?
YES! Type in "Sears Parts Direct" into your computer, list the whole model number, ( you are missing a couple numbers on the end ) and you will see all the parts and the manual, etc.
Be blessed.
May 29, 2014 | LG 24 in. LDS 5811 Built-in Dishwasher
When the LG dishwasher come on it try to start then le flashes and it dost start what do i do
You have a water fill problem.
Make sure the water supply is turned on.
Could be a bad water valve,bad wire bad timer,etc.
Copy and paste this Factory Service manual to help in diagnosis.
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
It may not be specific to your model number,you did not post a model number.
It should help generically.
Sep 14, 2010 | LG Dishwashers
Are there any service bulletins available for the LDS5811BB LG dishwasher?
Yes there are several bulletins for this model number and for different years.
Jul 19, 2010 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher is whistling a high pitch tune during washing
It is difficult to be specific without knowing the model number of your LG dishwasher.
On newer LG models, the most common cause of noises is from debris stuck in the lower filter assembly area. Recommend you remove the lower spray arm and the screws that holds the filter sub-assembly in. After removing the assembly, inspect with a flashlight to search for any debris that is jammed in that area. Also rinse out the filter as best possible to remove any thing you see in there. Reassemble and test.
Jul 30, 2009 | LG Dishwashers
LG LDF6810ST Won't Turn ON
If you are still having the problems you describe and especially is you are getting a leak from the lower left door panel, please provide the model number and the serial number.
There IS help available if you provide the info.
Please report back. Thanks!
Dec 27, 2008 | LG LDF6810ST Stainless Steel Built-in...
I HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Hello jaq1407Welcome
You said, You HAVE A LG DISHWASHER IT ONLY GOES THROUGH HALF CYCLE AND COMES UP WITH HE?
Please send me the model number and year!
Waiting your response
Oct 22, 2008 | Dishwashers
LG LDF8812 Stainless Steel Built-in Dishwasher Logo
96 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
