Hi there I have a diesel kipor generator and it gave me error code p-05. Only a week ago it was running fine and nothing changed between then and now. On the owners manual it says that it can be the starter motor, but my generator is still relatively new. Can it be a fuse or something else that is relatively obvious? Regards Markus
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: My kipor KGE 1000Ti starts fine but after several
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Thank you for your responses so far. It is a KDE19STA model. I have now checked all the fuses (all fine) and the oil level (also fine). On the underloading comment, I tried to put more load on it but it still does not want to start. After several attempts to start is, it suddenly moved (started to start for a split second, engine moved). Now every +- 5th attemp does the same? My first thought was that the battery does not have enough power to start the engine? Can this be true or what else can be the problem? Can I just use my car's battery as a test?
