And how do you run the cleaning solution through the milk tube? ive lost the manual and never had to do it before
Hi.
You put the cleaning tablets under the round lift up flap on top of the machine between the bean hoppers.
You put the tablet in when the display request it during the coffee cleaning program.
The milk cleaning solution is mixed 15ml in 250ml of water. Place the milk tubes in the solution and activate the cappuccino cleaning program which wil then also ask for clean water to rinse. Or just use the milk button.
Hope this helps.
<a herf ="http://www.coffeebeansandmachines.com/blog">best coffee makers</a>
Add a capfull of the cleaning fluid to a litre of water, insert milk tube and request cappuccino clean from the cleaning button...icon of cleaning tablet surrounded by water droplets, second row second button from lefthand side...then follow screen instructions to step your way through the cleaning selections with +and - buttons.
I keep the cleaning fluid held high to allow it to continue running after the cleaning action.
Remember to run clean water through the pipes using the same method above.
Google x7 manual and you can download one of many copies online.
