How do I factory reset my Cruz? ... What should I do if my Cruz Reader (R100 Series) will not turn on? ... Why does the headset audio sound strange on my T301? ... How do I connect to the Internet if I don't have Wi-Fi at home? ... through CruzTablet.com or one of our Official Retailers come with a One-year Limited Warranty ...
How do I connect to the Internet if I don't have Wi-Fi at home? How do I remove an ... How can I unlock my R100 or T301 if I forgot the pattern? How does storage ...
Amazon.com, Inc.Jun 19, 2011 - Velocity Micro T301 Cruz 7-Inch Android 2.0 Tablet (Black) ... Caity, Idon't know if this will solve your problem, too, but my ... Everything seems to be working just fine now. .... you have to is reset it and hold the power at the same time until comes back hold it for ... Worked perfectly, thanks for sharing the info!
???? what do you want to know, if its about the warranty and they tell you that they will send it for repair then don't accept it, tell them you want it replaced for a new one, if you got it second hand then it might be under warrant for 3 month,
If you just purchased this unit. Then it is covered under warranty. If power is the issue and you are sure it is charged. Then your unit has a bad Main board or battery. Either way, It is a Paper Weight for now!
http://www.cobyusa.com/?p=faq#faqcat_8 on this page you will find almost all answers for your questions related with the tablet ..(under internet tablets sector ) The issue in your case it is the internet connection itself ..either the wireless network you used it is not working anymore or not on (if you use a router ) ..or simply you reset the tablet and you need to make the connection again ..Just open the internet connections ..(wireless card 0 ..and select to scan for networks ...and when you find your network ..select ti ..and than click connect ..This should connect it right the way .. Also check if your internet network may need your mac address for to let you connect ..(this happens on the networks having the access restricted by the Mac address..) to get it follow these :
Click on Settings.
Click on Wireless & Networks.
Click on Wi-Fi Settings.
Click the MENU button, located on the side of the unit.
Click on "Advanced".
Your MAC address will appear in the Advance Menu ..
same way to get to the connection for to activate just open wifi connections ..
The whole tablet must have been flexed or something was set on the screen most likely, less likely but possible was a design fllaw.
Since replacing the screen itself is the most expensive repair, you might contact Coby US Residents: 877-302-2629
(Monday-Friday 9AM-9PM EST) Otherwise their support page on the web http://www.cobyusa.com/?p=support
If it cracked from normal expected use, they might have something to try make it right for you.
