Here are the steps which have been recommended by admin/mod people
1) Remove your SIM card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset (remove the battery while the device is on, then reinsert the battery).
6) Call your carrier and ask them to detach the device IMEI from your username.
7) Once step 6 is done, hard reset without your SIM card inserted.
i hope that is what you are looking for. however, keep in mind that if you call CC from a phone other than your sidekick they will walk you through the process. perhaps, you would like to hear it from them just to be safe.
SOURCE: looking for master reset fort-mobile sidekick lx
turn the phone off, once done hold the green and red buttons (call and end call) while holding the camara button and hold then on botton
SOURCE: how do i master reset sidekick
open the back near the memory card theres an arrow, press it.
SOURCE: need to reset privacy lock on sidekick lx
1: my sidekick lx is allowinq 2 differnet codes into my privacy lock . for example i change my code and it still allows my old code to enter , & it allows my new code .... what do i do ?
2: my aim away messaqes arent workinq to be very lonq ....
other sidekick users have very lonqqqqq away messaqes & they show up , but when i make a lonq away messaqe it doesnt work... why is this ?
3: when i put on my away messaqe " <3 " everythinq after does not show , i would like to know why ?
