Nikon COOLPIX L18 Digital Camera Logo
Anonymous Posted on May 05, 2009
Wrong batteries settings prevents access to menu
I have mistakenly changed the batterie type, for lithium batteries, I don´t have that kind of batteries, and when I turn on the camera, send a batteries exhausted error with my nickel metal batteries. So I can´t go back to the menu to change that wrong setting, turning off and on, the first that displays the camera is that error, so I can't enters the menu. Is there any way to make a hard reset to recover the defaults settings? or to change the batteries type or simulate lithium type batteries justo to enter to menu again? Of course I mean solving the problem without buying that kind of batteries Thanks, a lot and forgive my stupidity
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
268
Points
Charge fully the batteries you have, to prevents the camera distinguish the type of batteries (maybe the camera senses the charge), turn on the camera and you will have access to the menu to set up the batteries type correctly, that´s all.
HOW DO I CHANGE THE "DAY" ON MY WIND RIVER WATCH CR 2025 / 29678
Please don't type in all CAPS, it is considered SHOUTING and harder to read.
CR2025 is the battery type!
CR2025 Energizer Lithium Batteries (1 Pack of 5) - Amazon.ca
Amazon.ca https://www.amazon.ca > CR2025-Energizer-Lithium-...
Pack of five, 2025 3 volt lithium coin batteries; Cell size: 2025; Iec: cr2025; Replacement for: 280-205, 5003lc, br2025, dl2025, ecr2025, sb-t14 ...
Battery cell composition: Lithium Metal
Recommended uses for product: Watch
Number of batteries: 5 Lithium Metal batteries r...
https://www.google.com/search?q=WIND+RIVER+WATCH+29678+set+time
Mar 13, 2023 • The Watches
3helpful
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Change the battery setting
Hit menu, left and down to Set, then right and down many times to the second last item on screen 5 to get to battery type. Supports Lithium, Alkaline, Ni-MH
Can you use lithium batteries for Samsung BL103
Look in the menu on the battery feature...most cameras have 2 choices for batteries...and need to be set before changing the battery type..if it has in the battery (power feature) the choice to set it on the lithium ones..it means that will work ..if not ..use alkaline or ..get some rechargeable ..ones..cause they last more..and are not that expensive and can be recharged..
2helpful
I have a digipower lithium power charger TC-U100 and cannot get my Casio NP-60 battery to charge in it. Am I inserting it wrong?
Maybe. This unit charges all different kinds of batteries, but that requires you to make sure that you have set the prongs in the right position to connect with the particular battery you are charging. You move two pins to align with the outer contacts on your battery (not the middle one) and then a spring door holds the battery against them. The unit sets the polarity automatically. 4 lights blink green until the battery is fully charged at 4 solid lights, i.e. 1 blinking light is a quarter charged.
Camera showing battery exhausted with new batteries
There are three battery type settings in the set up menu: Alkaline, COOLPiX(NiMH) and Lithium. Might be worth looking at. To be continued.
1helpful
Don't know what this red thing is on the screen
There is an option for changing battery types in the menu. The accs that came with my camera where very good Lithium-Mh type. If replaced with ordinary Alkaline non-rechargable, you have to adjust battery settings, probably also if you got the very expensive Lithium-Ion batterys. The thig is that these three types has different voltages; 1.2, 1.5 and 3.2 (I think) respectivly.
Wrong settings could perhaps cause this your problem.
2answers
"Battery Empty" sign with camera shut off
You may try to set in setup the kind of batteries you are using. Many digital cameras allow you to set the kind of batteries being used. Whether or not this will solve the problem, is yet to be seen.
2answers
HELP!
Use lithium batteries. I had a problem when our camera would turn on for a few seconds, beep 3 times, and then shut off. The best batteries, which are actually recomended for this camera is the lithium batteries. I strongly suggest them.
1helpful
5answers
Wont last
use batteries with lithium mine has lasted me over a year
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
