No. The pilot light uses a thermocouple(safety device) to let the main gas valve know that the pilot is lit so that the main gas valve can operate safely by not letting the main gas valve turn on without a lit pilot light. This way, in no way can the main gas valve turn on until the heat from the pilot light causes the thermocouple to produce an electrical current which allows the main gas valve to operate when the thermostat switch closes.
If you have a standing pilot and it is not on, you should be smelling gas in the house. Try lighting it with a BBq lighter directly. On some stoves, you will have to press a button and hold that button for some time ..over a minute..while you have the light to the middle of the pilot. Do not proceed to light the pilot until there is no more smell of gas in the oven.
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
pilot over lights do not require power to stay light or should it go out in a power outage! do you have to normally light pilot with a match? if not you have a glow coil and its a electronic ignition range and power will affect it. once power is restored you should just be able to turn on over and everything would be ok.if it is a pilot light you need to remove the bottom door stick arm in to back and you'll see the pilot assembly at back if you look up! hopethis helps...
Most commercial ovens have a manually lit pilot. There will be a button somewhere on the range that you will need to push in so gas will come out of the pilot assembly. While holding this button you will the light the pilot and will need to hold the button in for about a minute or two until the pilot stays on after you release the button. Look around the bottom panel,top panel or side panels(you may need to remove one) to find the button. they are usually red and may not look like a button. If you find the button and the pilot does not stay lit then the thermocouple might be bad. If you push the button and do not get any gas coming out of the pilot then there might be debris in the pilot assembly causing the gas not to come out. In that case you could try and tap the assembly or blow with compressed air to clear it. But in most cases you will need to remove the pilot assembly and use a really fine wire(like a metal tie-strap minus the coating) to clear the pilot orfice.
Relighting Your Furnace's Pilot Light
Turn off the gas at the main valve at your utility box
Wait five to ten minutes for gas fumes to waft away
Get a long match—yes, a fireplace match, not a standard match
Set the gas valve on your furnace to "pilot"
Press the red button as you hold the match to the pilot valve
Keep pressing the red button for 30-60 seconds so the pilot can heat the
thermocouple. Release the button and see if the pilot remains lit
If pilot goes out, wait five to ten minutes and repeat the process
Once the pilot stays lit, turn the main gas valve back on
If the pilot light continues to go out, call a technician, who may need
to adjust or replace your thermocouple or adjust your pilot
