Directv (R10) DTV Receiver / 70-Hours Video Recorder Logo
Posted on May 05, 2009
On comcast i cant tape 2 shows and watch another
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
12753
Points
94
You can tape 2 and watch one that is recorded, it has a dual tuner to record 2 shows. you can record one and watch another channel at the same time.
Hope this helps
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
After downloading the xfinity app, the tablet won't play shows/movies correctly.
Comcast has a great Customer Service. Contact them for help. You might need some add-ons.
Comcast.com
1helpful
MITSUBISHI VS-60705 Comcast related. Power went off, TV was not showing comcast anymore, I tried installing Channel Plus + and now cannot abort the message. The message has been on TV for 3 days already....
Check with comcast but have you tried to remove power from all units involved here for a while, then power back to see if the reboot will help or not.
Splitter side of Comcast cable signal unusable. Converter box OK
DTR's are available everywhere. You can also go online and purchase one if your local stores do not have. Also, keep in mind that the splitter you use must comply with the signals unless you use the Video output of DTR.
1helpful
As required by Comcast, I just installed a Comcast digital tranport adapter, DC50X, to my TV that also has a Series 2 Tivo connected. After activiating the Comcast box, I can't view shows that Tivo is...
There comming out with a udate stay tuned, and please check your cableing as we discussed in chat earlier, and rate this one too thanks..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Digital TV Converter Box
I have a Panasonic TV with built-in VCR, I had Comcast put in a converter box and was given instructions on how to set up the system to record my wife's programs, I had to select the program (in advance of scheduled time) to be recorded through the TV & converter box to the VCR. Next styep- select "Show" and I received a menu the first of which was "R" I clicked the "R" and a menu for selecting Repeat record start/stop times appeared Click OK and was then directed to to set up the VCR according to Panasonic VCR instructions. Worked for a day then the "R" menu on the converter box disappeared. Both the VCR and TV had to be set to Ch 3 to get it to work, But that's history. When it quit working ("R" menu), I had Comcast come get their box . PS The tech who showed up to pick up the converter box knew nothing about any "R" (record) menus except on the most ecpensive converter box. That cinched my decision, Oh Wel!. Sign me Tom with less trash to watch.
Can't tape tv program on VCR while watching another show on digital cable.
If you set it up right per Comcast instructions:
Your VCR will record a show off of its built in tuner while you are watching another show from the cable box.
Make sure that the AB switch is set into the correct position and that you are only recording a show that that isn't digital. I believe you can only record shows up to channel 150 off the VCR tuner. Anything higher than that won't work.
If your Comcast Cable Tuner has two AV outputs in the back of it, you can skip the AB switch altogether and plug the one of the cable tuner output lines into the back of the VCR input lines. That way it can record that show you are watching on the cable tuner at that same time.
Top Directv Televison & Video Experts
Alexander
Ngoro
john h
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
