Rheem RTG-66DVN Direct Vent Natural Gas Logo
A
Anonymous Posted on Nov 16, 2013
Eternal error code e03 - Rheem RTG-66DVN Direct Vent Natural Gas
Why is my Eternal hybrid tankless water heater leaking from the bottom?
After a year of trying to correct the problems, Grand Hall, the parent company of Eternal Water Heaters, ceased operations in North America leaving their customers without warranty coverage, part replacements and technical resources
Unfortunately you may have to replace it.
No one can tell you without inspection unit. I found this link with the same problem, have a look
https://www.youtube.com/watch?v=cWmkeyw_hsU
3answers
E28 error. Why does the thermal fuse keep blowing out?
If the thermostat is not functioning properly the heater will run "wide open" and overheat.
Whirlpool f08
whirlpool f08
f08 e03 error codeF8E2 is DISPENSER SYSTEM ERROR - Dispenser motor is unable to reach the desired position. Possible causes: Check the mechanical linkage from the dispensor motor to top of dispenser. See TEST #12 (Dispensor Distribution System) on page 21. Someone else can post to contents of Page 21. Good luck.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTou7Nz
Yes, it is a dispenser system error. The technician manual says to check the mechanical linkage from dispenser motor to top of dispenser.
However, in my case this page from whirlpool was helpful:
https://www.whirlpool.com/product-he...r-code/PH5260/
It says a common solution for this error (f8 e2) is:
The detergent drawer or detergent cartridge might be clogged with detergent. Clean out the detergent cartridge per Use and Care Instructions.
If cleaning the detergent cartridge did not correct the problem, please contact us.
For any additional questions, please call our Customer eXperience Center toll-free at 1-866-698-2538, Monday through Friday 8AM-8PM Eastern Standard Time.
You will be asked to provide the model and serial number which is found on the front door rim after opening the door.
So I washed out my dispenser and now it's working again.
Read more: http://forum.appliancepartspros.com/washer-repair/529426-f08-e02-error-codes.html#ixzz34yTzjNdt
2answers
Eternal hot water heater error code e11
I cannot find what e11 means but it seems most people have just unplugged it an it came back on. Code goes away.
1helpful
Eternal GU-195S Hybrid water heater
Is this new installation? Or old installation that stopped working?
Here's the 100% solution. And it applies to all brands, models, types, of tankless water heater, no matter which error code:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
People should avoid complicated water heaters that claim 'energy star' and '98% efficiency' while proclaiming 'endless hot water' as if the laws of physics, economics and common sense can suddenly be suspended if only the customer would buy expensive, complicated water heater that cannot be maintained or repaired by customer, and there are no qualified technicians who live in your area.
Otherwise you need a service manual, or contact eternal manufacturer. 1-866-946-1096
http://eternalwaterheater.com/pdf/downloads/GU100.pdf
Error E02 does not show in manual.
E2 is ignition failure, which on other brands can be failed PC board... and inadequate incoming air supply, or venting, or failed sensor, dirty combustion parts, air or water in gas line, low gas pressure, wrong gas, etc, or multiples from list above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Eternal water heater sa 06 code
What does it mean when the Eternal tankless water heater reads a SA.06 code when you press "diagnosis" button on the front???? We only get about a minute of hot water and then it goes cold. Customer service 24/7 phone # 1-866-946-1096 is OUT OF SERVICE!!!
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
