Televison & Video Logo
A
Anonymous Posted on Nov 16, 2013
Instructions rcl 3000 lantern
Want to purchase tube light bulbs.
Lawrence Oravetz
Level 3:
  • Televison & ... Master 10,558 Answers
  • Posted on Oct 08, 2016
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2694822
Points
29284
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on Nov 06, 2012
SOURCE: RCL 3000 remote controlled lantern appears charged but the lights will only flicker when you pull the charger in and out as if there is a short or something
Check its battery. It might be weak. Replace it and check.
I have a RCL 3000 remote control Lantern won't keep a charge
It looks like it is around 23 years old. Made in China. See if you can send it back for repair :>D
The most likely cause is something not connected during the battery change over. It worked on the battery power when it was installed, but when it ran out, the charging circuit has a break somewhere and is not recharging. Also check the charger for Output Voltage. It is a 12 volt charger
https://fccid.io/NW9-RCL3000R/Test-Report/3000-25688
https://www.google.com/search?q=RCL+3000+remote+control+Lantern
Feb 05, 2022 • Home
2helpful
2answers
Manual for coleman lantern model 5348-700
simple unscrew the top clockwise and you will see how the tubes are removed,
5helpful
4answers
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
