Question about Rotel RMB-1095 Power Amplifier
Rotel rx 1050...Not working
I have the Rotel RX1050 and Rotel rb 1070. pre-amp out to Amp inputs hooked up. speakers hooked up. cd player hooked up. Zone cd and cd selected. and, Yes, the power is on. also both A and B speakers are selected and LED lights on. But NO SOUND. nothing! Is the receiver blown? Even though it's a few years old, it's been barely used. Is there something that is NOT on or needs to be off? I don't get it. thanks s
  • Anonymous Mar 15, 2014
    loose rca input on rotel rb 980bx
  • Anonymous Mar 29, 2014
    static crackling sounds on rotel pre amp
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
Posted on Feb 12, 2008
  • 93 Answers
Try only A speakers.
Posted on Oct 08, 2007
SOURCE:
Idealistic graphic equaliser model 31-9081
Connect your Denon outputs to the Realistic main inputs.
Connect your Realistic main out to the Rotel tuner in.
Connect your Technics out puts to the Realistic Tape 1 inputs.
Connect your tape 1 out puts to your Rotel cd inputs.
And you should be good to go.
May 02, 2016 | Audio Players & Recorders
How to connect my Bose 901 series vI speaker to yamaha rx v740 and rotel rb 1582. Appreciate your help. Thanks
The Bose controller gets wired in series between the pre-amp and the power amp.
I presume you plan to use the 901's as the front L&R pair. So the cables going from the 740's Pre-Out Front L&R go to the inputs on the Bose controller. The outputs of the Bose controller go to the power amp Front L&R channel inputs.
Aug 17, 2014 | Audio Players & Recorders
Getting no sound hooked up to pre-amp and 2 rotel 200w amps with snell speakers
You didn't say whether the player is connected by 2 RCA cables (analog) or by digital cable. If by RCA, does the player have a headphone jack? I had a player once with a piece of a headphone that broke off inside the jack, muting the analog outputs.
May 16, 2014 | Sony CDP-CX300 CD Player
Hookup Blu ray player to Onkyo pre-amp for speakers
If you have audio out jacks from your tv, you would be better served hooking that up to the preamp. If you hook up the blu-ray player separately to both the tv and amp, the audio probably will not sync with the video correctly. The tv takes longer to decode the hdmi input and the audio will be ahead.
Jan 22, 2013 | Onkyo Audio Players & Recorders
Hi, I have a Rotel 1050 receiver that I am trying to hook up to a NAD 2400 THX amp. I do not know how to "bridge" the connections so that the Rotel amps are not disabled. Any help is appreciated.
I think the best solution is to remove the jumpers from the Pre Out - Mon In connectors, insert a pair of RCA Y-adapters and plug one end back to the Mon In while the other ends feed the NAD (Page 15 of the manual available at Retrevo.com) . The Rotel's volume and other controls will still be in charge of the NAD.
The manual fails to mention looping the Pre Out back to the Mon In to enable the Rotel's amp to still participate in the program material.
Apr 10, 2010 | Rotel RMB-1095 Power Amplifier
I am looking to upgrade my receiver to an audio video receiver that will hook up to a blue ray via HDMI. I want to use my 901's forthe front speakers. Can you recommend a mid priced (<$600) AVR that...
Good day,
Congrats on your new AV receiver. I own an awesome Yamaha mid-priced AV surround sound system with HDMI, BR disc player, and all that stuff. However, I'm old school and use my 901 Series Vs with a Yamaha RX-797 'two-channel' receiver. To get to the point, I have some bad news. Mid-priced (mp) AVRs, or any AVR for that matter, will not work with 901s because the active equalizer (EQ) requires either a 'tape monitor loop' or 'pre-out / main-in' connection to work properly. You've probably been told the 'why they won't work' by now and it is very true--I know from experience. Most of today's AVRs do not include a 'tape monitor loop' or 'pre-out/main-in connection for the EQ connection, thus, killing all hopes of using 901s. I truly love my 901 Series Vs (since 1985 and still kicking) and love true 'stereo' for playing my music. Again, 901s are useless with today's AVR equipment (as I know it). Just don't let your 901s collect dust--they are truly marvels!! Go with a set of good 'standard' speakers for the AVR system and buy yourself a decent stereo receiver or amp for the 901s--that's how I do it!! I've tried Onkyo, Rotel, Sansui, Poineer amps / receivers--all of them. I can tell you this--for the common, working man/woman, nothing, I mean nothing available can match-up with Bose 901s like a Yamaha RX-797 (200W)--not to mention the sound quality-wow!!! And this unit is very reasonably priced for such awesome performance and high quality build. Just know that all is not lost. You can still use your 901s--I cna't listen to music without mine.
Aug 24, 2009 | Bose 901 VI Main / Stereo Speaker
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
721 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
