My laptop wi fi iis not connected
Have you checked to ensure the WiFi switch is turned on? The computer with the red X is typically to let you know that connection is off (or in the case of the port that there is no hardline). Basically the 2 computer are one hardline, one wifi. Make sure the WiFi switch is on. It is usually a physical switch on the front for Sony laptops.
SOURCE: ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model
listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from
the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or
later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update
VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download
directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
SOURCE: sony vgn-nr120e wifi not working - wireless lan
reinstall your wireless drivers..
this problem is due to not driver correctly installed
SOURCE: Vaio wireless lan switch repeatedly restarts windows
Thats sounds like the wrong drivers for the network card. Some models can have different models or brands of cards so you can get the wrong one in there. You should be able to boot up in safe mode (F8) and then go under control panel - system- hardware manager-network adapters. Find the card that is causing the problems highlight and delete it. Then reboot. This takes the card out of the system and it will be detected as a new hardware next startup. Then try another driver.
You might want to go to the Sony website and check under support to see what other drivers you can get to try for your model. There might be 2-3 to try. Usually the oem disks are right but the replacements don't always get things right.
If this were hardware you shouldn't get the bluescreen of death (BSOD). That usually means software or drivers.
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
You can download the SmartWi Connection Utility from here.
SOURCE: VAIO VGN-Z520N/B 13.1" Laptop : where is the volume control on sony vaio laptop...
You can use the Fn+F3/F4 Function Keys to control the volume.
To increase the Volume, press Fn+F4 and then press Up or Right, or Keep pressig Fn+F4.
To decrease the volume, press Fn+F3 and then press Down or left, or Keep pressing Fn+F3.
Hope this helps..
