The screen will not come out and the unit will not play. The blue light comes on to switch from radio/cd/tv, etc. and the red light comes on when you push cd eject, but otherwise it will not play any
It will not poer on. The blue light comes on on the button to switch to radio, cd, tv,etc. and the red light comes on when you push eject. However, the unit will not play anything or the screen will not come out.
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring DiagramRadio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Hi, the factory radio uses the illumination wire, but the aftermarket
radio does not. You have to make sure that wire is taped off so it
doesn't short the illumination circuit. Check your tail lights fuse.
If it's blown, pull the head unit and disconnect/tape off the
illumination wire (blue with a white stripe) from the factory harness.
Then put in a fresh fuse. If you have more questions, please specify
the model of the head unit.
1991 Ford Festiva Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Red/Black
Car Radio Illumination Wire: Blue/White
Left Front Speaker Positive Wire (+): Blue/Red
Left Front Speaker Negative Wire (-): Blue/Yellow
Right Front Speaker Positive Wire (+): Blue
Right Front Speaker Negative Wire (-): Blue/White
Left Rear Speaker Positive Wire (+): Blue/Red
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Green
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Red/Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Negative Wire (-): Pink
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis or Strap Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: Orange Car Stereo Antenna Trigger Wire: Orange/Red Car Stereo Cell Phone Mute Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: Located under the rear deck in the trunk. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Is the adapter getting hot ,then you replace the adapter else you can check the o/p of the adapter with help of multimeter it read 12 volts ,if it reads 12 then there is problem with tv itself..
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
your radio has 2 blue wires. one of them provides a 12 volt turn on for a power antenna (when a cd is inserted that 12 volt turn on turns off, because when a cd is playing, the antenna doesn't need to be raised up). The other blue wire has a 12 volt turn whenever the radio or the cd is turned on--this is the blue wire that you need to connect to your amp remote line. ( pull out the radio and switch the blue wires)
respectfully,
Merle
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe Car Radio Ground Wire = Black Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe Car Radio Dimmer Wire = Light Blue w/ Red Stripe Car Radio Illumination Wire = Orange w/ Black Stripe ?? Don't know ?? Red Wire (No power to wire Constant or Accessory) Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front: White w/ Green Stripe (+) Brown (no stripe) (-)
Right Rear: Purple w/ White Stripe (+) Light Blue (no stripe) (-)
Left Front: Light Green (no stripe) (+) White w/ Orange Stripe (-)
Left Rear: Light Blue w/ Black Stripe (+) Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front: White w/ Green Stripe (+) Green w/ Orange Stripe (-)
Right Rear: Orange w/ Red Stripe (+) Black w/ White Stripe (-)
Left Front: Orange w/ Green Stripe (+) Blue w/ White Stripe (-)
Left Rear: Red w/ Green Stripe (+) Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
