Of course, the bypass is causing problems to check engine light comes on. the cause could be the thermostat also. do you replace it frequently? sometimes the temp sensor becomes dirty, I'm not sure about the location, would be one or two sensors.
You need an auto-electrician to connect a code reader or a pro grade scan tool computer that can scan data in real time. It will tell what is happening when the car starts to fail.
? 0:25 www.youtube.com/watch?v=GWIcTycQFYI
Feb 16, 2013 - Uploaded by Arash Soltani
rio-side-mirror removal-04 - atomia.ir. ... Drivers Side MirrorReplacement ' Kia Sedona ' Other Makes ...
www.kia-forums.com > Kia Forum > KIA Models [Archive] Life is more colourful with Picanto. ... Picanto 2007 auto transmission abrupt start problem · Driver side door lock problem (2005 picanto) · Picanto 1.0 lx ...
kia seems to do things somewhat right censor should be close to thermostat. look for wires going in around thermostat. Easy way to check. Bring motor to running temp.look or listen if fans or coming on. Also could be a relay in fuse box.Jump them over and see if fans come on. but that's another Q&A
Check with the place that checked the codes for you. Maybe they can test the IG sensor for you. That might help. Otherwise check all the connections relating to the sensor.
