LG Vu CU920 Cellular Phone Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone gets too hot!!!!
When I'm on my phone for more than 6 minutes the phone gets really hot, almost too hot to leave by my ear. It is really uncomfortable and I'm not sure if anyone else has had this issue?
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
3715
Points
48
As ur phone is a touch screen it has the right to get hot as these phones' interfaces use too much battery.my phone does that as well specially when wifi is on or im playing a game.so its normal.ive used an iphone as well and it has the same problem.so dont worry
Anonymous
Level 2:
  • Expert 315 Answers
Anonymous
Expert
Level 2:
Answers
315
Questions
Helped
119334
Points
973
Hello, this is a Bettery issue, if your phone is still under warenty then get it changed......
Kevin Cisco
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 13, 2017
Kevin Cisco
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
246
Points
Generally speaking, there are two main reasons resulting in iPhone getting hot: system-on-chip (CPU) and battery, both of which are influenced by the following situations:
1) Watching high-quality videos and TV shows
2) Playing demanding and heavy games
3) Running some processor-intensive apps
4) Using iPhone when charging
5) Exposing iPhone to sunlight
6) Employing bad quality battery
7) Adopting some poor quality case
8) Using Map directions and GPS
Why Does My iPhone Get Hot Fixed
2answers
How do I. get. music from my phone to play thru my home stereos receivers
I'm assuming u have bluetooth on stereo find bluetooth on ur phone, turn it on and find the device u need. I do it old fashion way with cord has headphone jack on one end to plug in phone and red and white to plug into stereo. If u really want low tech cassette tape with headphone jack works too.
Camera wont come on battery gets really hot
if it is a digical if so the batteries have to be rechargeable and be over 1000 because the rest just arnt good enough . because of the technolgy in the camara , and because of what it can do do . the batteries have to be the best . their will be more power comeing out of the camara and excceds the battereis. its like a mobile phone , the phone is a 16 volt batteri and you plug a 5 voult charger in the phone . it gets realy hot because their is insufficaint charger for the volt . we wiill have almost blew the charge on the batteris aswell as the connection on the camara or ie [phone]. leave for 24 hours and then try the rechargeable energizer 2000 plus is one of the best .replace the old for new and try the enegizers
2answers
My e5 got little wet and now am having trouble with itz display!!!!!
how wet is a little wet
you still might have some moisture in the phone dry it out completely
use a hair dryer but dont get it too hot
you might have to use the hair dryer every 10-20 minutes depending on how hot it gets
you might even dismantle the phone to dry it out
hope this helps
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
2helpful
Ear piece
That's pretty cool i'm jealous ha ha but if you really want to hear that stuff, your going to have to get a new ear piece. This one sounds like it's made to filter through that stuff. Otherwise your ear piece just might need to be replaced. If it's still under warranty I would suggest getting a replacement one sent out to you. Hope I helped!
16helpful
8answers
LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
4answers
Kyrocera kx5 slider remix
I guess this is a common problem huh. No worries!
First: Click on your music button and play a song as you would normally do on your phone (make sure your speaker is on during this point).
Second: Click on the speaker button so you can listen to your music through your ear piece (as your music is still playing). If you don't hear your music through your ear piece wait until you hear it. It shouldn't take more than a minute. (Your music should be playing throughout this whole process)
Follow these steps every time you come across this problem.
If this solution resolved your problem, please leave a comment and a good rate. Thank you!
Phones ear speaker stopped working?
2answers
N-gage no sound
It Appears some sensor is miss feeding the central processing unit. Try taking off the battery for a few minutes if it does not help check the ear phone plug for dirt, maybe something is closing the circuit. Good Luck!
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
