In a typical configuration you will need to connect the receiver to another device such as a mixer console. The mixer is connected to an amplifier. And lastly, the amplifier is connected to speakers.
Without more information, such as existing equipment in the configuration, I am limited to how much I can help you.
What are you trying to acheive (band, karioke, voice reinforcement, etc.)
What environment are you doing it in?
What equipment do you have besides the mic and receiver?
Your recorder is mostly analogue with just a hdmi output, you need to link up using a scart lead or similar adapter lead for recording, looks to me like scart 1 (decoder) or the front sockets for input use while. the other scart looks to be just for TV to use.
If your TV has another hdmi then I would have thought your sky sat would connect that way leaving the scart for your video.
Though if it has only one, then you are looking at a multi input box for hdmi (some are automatic others have remote control) or demote your video's hdmi lead and connect it to the Sky sat, use the scart lead to link it with the video's scart 1 and the other scart socket to TV by the look of things.
Its a problem with older and younger equipment because they are built at different times with their connections decided by that time of manufacture.
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
your video card (not tv tuner) has to connect to your tv. you would then use your tv as your computer monitor. If you dont have all the proper connections to connect your video card in your pc to your tv, then you may have to use a different video card. It just depends on what tv and video card you have
Lots of people are doing this and part depends on what your home theatre has to offer in the way of connections.
For sound most use the LINE OUT on a computer or laptop and connect that to a suitable input on the receiver using a 3.5mm to stereo phono lead.
If you are lucky enough to have an OPTICAL sound out on your computer and one on the home system that would be a better option.
For the video side again it depends on what your computer has to offer
If it has DVI and your TV or home system has DMI then that is the very best option. remember to lower the resolution on the computer first and to check and of your graphics card options for dual display. A DVI to HDMI lead is needed for that
Nvidia graphics cards seem to work best in this area.
If you have a VGA connector on your TV that is another great option and you would only need a VGA lead.
Some cards and laptops have S-VIDEO out. Lots of TV's and home systems have these and the display is quite reasonable. If using S-video connections use a GOOD quality cable.
Some people can only obtain a black and white picture so check your graphics card did not come with any special adaptor.
Another method is composite video Even that is not always 100%
Some laptops need a special S-video adaptor which is just a short little cable to properly enable the S-video and convert S-video to composite. That is probably the worst way to do it.
Using a VGA to component lead is also an option but results vary wildly from no picture to quite good. A lot depends on the quality of the lead once again.
I use the optical sound and DMI lead to power a 50" Sony with great sound and picture.
Ok 2 questions? Are you connecting it via the scart RGB lead sold with the product, If so connect it using the colors on the leads with the corresponding colors on the scart
Or using a HDMI lead. Connect corresponding colors to the back of the TV,
If I remember correctly the master system only has one lead that looks a bit like an antenna connection, one goes into the back of the console and the other goes into the antenna input on the tv.
Then you need to plug the console in to mains outlet turn it on and tune in your tv to pick it up. I normally plug it into the antenna outlet and switch my channel on to the same channel that picks up the vcr, and it works
I think that the audio/video cables only work when s-video is not used at the same input. In other words if you use video 1 as a s-video input, you can't use the video port on video 1 with a video cable. Also, when you hook up s-video you must use a/v cables as L) and R) audio along with it. It really doesn't matter in which order audio cables are either. Hope this helps, Russmann.
