Hello, Yolie312000 -
I believe you will need to have an AT&T (AT&T Uverse?) technician scheduled to come to your home to check on your WiFi connection.
We have AT&T Uverse for our Internet service provider and experienced WiFi speed slowdown a couple of years ago. We telephoned the AT&T service number, spoke with an AT&T Customer Service Representative for technical issues. He scheduled a repair technician who solved our problems.
You will need your account number and PIN when you speak with the Customer Service Representative.
This is the number to call: 800-288-2020.
Best wishes.
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
SOURCE: My pc won't connect to the internet
It is the MAC address that needs to be scrubbed from the modem.
power off the desktop, power off the modem, unplug the data cable from the modem, unplug the POWER connection to the modem.
WAIT 3 MINUTES
Connect power to modem, let it reset
Connect data cable to Modem
power on computer
Modem should now connect & work with desktop.
Each time you switch between systems, you may have to do this. More than enough to make me buy a router. =)
Please rate the post. =)
SOURCE: cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
SOURCE: no ip address from modem to linksys wrt160 n router
1).turn off the modem and the router.disconnected from the Internet ISP. and the computer.
2).disconnect the router from the modem.
3).turn on the modem.
4).connect the router to the modem, and turn on the router.
5).connected the computer to the router, adn turn on the computer.
if you are using wireless, waited about 5 minutes before turning it on.
goto control panel>>wireless network, and configure the wireless seting.
SOURCE: cannot make a wireless connectiio work with Comcast internet
- Once you already configured the settings on your router, and 2nd step that you do now is to power cycle the modem and the router completely for about a minute.
Note:
- You must also remove the battery back up of your cable modem in order to refresh the settings on it.
- After the power cycling procedure, turn On 1st the modem and make sure all the link lights on your modem are completely stable before you turn On the router.
Are you talking about wireless connection to the router? The pop up is your computer desktop?
