SOURCE: How do I switch my Homelite Vac Attack II to a
Here's an online manual you can download to walk you through it.
http://lawnandgarden.owneriq.net/manuals/mfg/homelite/vac_attack_ii_blower_vacuum_zr08107.html
Hope this helps.
SOURCE: what is the gas ratio for Homelite Vac Attack II
The mix that I would use is one ounce of two cycle oil per quart or four ounces of two cycle oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Testimonial: "thanks. "
SOURCE: does this blower use 2 cycle mix
Yes it will use a fuel mixture of 40:1(3.2 oz of two cycle oil to 1 gallon of gas). Any fuel sitting over 30 days now is considered bad fuel. All the manufacturers schools this year and told us this. We are finding it to be true.
Good day.
SOURCE: I need the proper gap for a new spark plug for my
Proper gap is .030 inch.
Hope this helps,
Dolf-
Testimonial: "got the proper gap from the homelite manual online (.025) thanks"
SOURCE: I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
