I have just bought a used La Pavoni commercial burr coffee grinder. It has an adjustment for coarseness of the grind - there is a chrome ring with numbers on it and, below that, there is a black plastic ring marked coarse in one directio and fine in the other. There is also a spring loaded tab which has to be pushed down, however, neither the chrome ring nor the black plastic ring seem free to rotate when the tab is pressed. Could someone tell me which ring is supposed to rotate and whether I am missing the point!?
Thanks in anticipation,
John (U.K.)
SOURCE: Cleaning La Pavoni Burr Coffee Grinder
You'll need to remove the hopper and grind out all the beans. Then, with the lock tab depressed (if it has one), unscrew the grind adjusting collar out of the body. Once it's out, there are three screws (sometimes only two) holding each burr. Remove screws and separate the burrs. Clean away!
Be very careful putting it back together so that you don't cross-thread the collar into the body. Clean threads can help this.
SOURCE: La Pavoni Coffee Grinder PA Burr
usualy reserable termic fuses are attached to body of motor, or inside the winding wires of motor.
