I was watching a hockey game with no problems, when all of a sudden the audio stopped working, while the video remained. I just replaced the lamp in this unit less than a week ago, now this. Any ideas how to fix this problem.
I have had this same problem. First time it happened, I turned off the set for awhile and it sound came back. Now, no sound. Would like to know I anyone else is having the problem and found a resolution.
I just chosen Steps Of How To Become A Game Tester for Field Hockey. I really like participating in video game and Mario Kart Wii is my personal most loved video game
The Video (Picture) is SEPERATE from the Audio component of the TV. One can work when the other has gone south. From what I see, the Audio controller board may have been damaged somehow and needs to be replaced. Contact a serviceman for details.
This is not a big issue u ant watch 5th camera coz u had stopped other 122 cameras from working in GV eries you are allowed to stop remaining cameras from working to avoid video lost beep and video lost screen you can again start remaining cameras from here:in main menu (configure) 2nd option from top CAMERA/AUDIO INTALL ===> click on activate ===> activate the cameras as muich you want hope my post helped u
If audio suddenly stopped working, check if it is in mute, then unmute it. If same problem then you may uninstall and reinstall the audio driver that is on the device manager.
here's how
control panel (classic view)/device manager/sound and video game controller/uninstall the high def audio driver and restart the laptop and reinstall.
Check sound on "Tuner" input. If still no audio, post a comment with your other equipment makes and models as well as cabeling and I can help some more.
This could be a very simple problem. On the a/v cord jack, look on the part that gets plugged into the x-box. There is a switch that allows you to change from HD to standard format. I had this problem when I took my x-box to my brothers and he hooked it up to an HDTV. All you have to do is set the switch back to standard (or HD).
It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
Audio but No Video/Picture Problem can be fixed with the help of This DIY Video Guide, I would suggest you to give it a try as it also provide Money Back Guarantee.
Note:
If you are facing this problem either you can send your Xbox to
Microsoft for repair, if yon can wait for 2-3 weeks then it is good
otherwise you can fix the problem yourself within an hour with the help
of above Video Guide.
