Rotel rb1080 amplifier has a hum in left channel. can hear the hum in the left speaker.
SOURCE: Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
SOURCE: Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
SOURCE: Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
SOURCE: Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
