I got a response from Audiovox for my query about reseting the factory default parental pin. Watch this you tube Video hopefully it should help. http://www.youtube.com/watch?v=chVs56AQNik
if you don't know the parental code remove the power lead for a few hours then plug power in and hold down the power button on the front at the same time it should reset to factory settings. but it needs the power drain to do this. has to be for a few hours as child lock is on.
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental
code. You can either insert a restricted disc, or enter the DVD setup
menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press and hold the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness
of the player. The lower the value, the more strict it will be. Either
increase the value to lower the restriction, or disable the lock
entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is
empty, and press the RESET button on the front of the Playstation 2. It
is imperative the tray is clear of any DVD or game for the unit to save
your settings.
Your master password is 0000000 until you can't fit anymore into the space. Then reset to whatever you want. You are then able to go into the parental control and change it. Be sure they are all U as B is unable to view.
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
