Question about BigHorn 4 Bike Carrier
My Isuzu Bighorn Plaiser 3.1 turbo diesel is draining the battery whilst it is running. It will only happen when the motor is hot. I can start it repeatedly if I stop and start, such as driving around town. However, if I drive for any length of time, such as half an hour, turn it off, then try to start it within minutes, the battery can hardly turn the motor over. What could be the problem.
    Top Expert:
  • Yakima Master
  • 51,372 Answers
You don't say how old the battery is but it may need to be replaced.
Posted on Nov 15, 2013
SOURCE:
1992 isuzu bighorn 3.1 turbo diesel, rebuilt injection pump, will not cold start
1: compression good.
2: glow plugs hot.
3: test fuel, does test fuel work??????
yes, you did it wrong
no, #1 or #2 caused.
Aug 27, 2014 | Isuzu Cars & Trucks
Isuzu bighorn diesel
run the fault codes to find the reason for the engine light and the transmission light
Mar 14, 2014 | Cars & Trucks
I cannot start my isuzu bighorn w/4jx1 engine. we already changed the turbo but still it emits too much smoke in the exhaust and after a while the engine goes wild and we cannot turn it off in the ign
Its a diesel and its running away so do not try to start till you do the following and yes i know i will be amolished for being a cowboy by the other experts but what you do is to make a gasket for the EGR valve from a coca cola can and seal it off if you dont it may run away and blow itself to pieces .If you do this then it run as normal as the older trucks never had these thing fitted and they all run ok in my day ,exactly whats wron i couldnt tell you without my head under the bonnet but do as i say and it run perfectly
Mar 22, 2012 | 1998 Isuzu Trooper
Need workshop manual isuzu bighorn 1996
1996 model Isuzu bighorn plaisir 3.1 D engineoil
Jan 14, 2012 | Cars & Trucks
My bighorn is 1998 moder turbo diesel. I was running around 80 kph and engine suddenly stop. Tried to restart but engine failed to run.
hi..
-this may because of the seizure of the engine. the piston may got seized with the liner. this happens because the engine oil is not sufficient to lubricate the moving parts. try to service the engine that is the only way for getting back the engine and keep a good track of yout engine oil
Jun 29, 2010 | Cars & Trucks
Replace speedo sensor on isuzu
www.myisuzuparts.com you need a speedo gear
May 30, 2010 | 1992 Isuzu Trooper
Turbo timer installation 94 isuzu bighorn
CAN YOU FIND IT THE ENGINE AND A/T WIRING DIAGRAM
May 03, 2009 | 1994 Isuzu Trooper
1998 Isuzu Bighorn Diesel. The car just won't start. My local dealer can start it using a cold start spray. But he has not been able to solve the problem. Please could somebody help
I have a 1998 Bighorn 3.0L if the wrong grade of oil is used in the motor it miss fires and runs rough, due to the injectors being oil pressure controlled, I have heard of extreme cases causing a failure to start when cold. good luck
Feb 17, 2009 | 1997 Isuzu Trooper
Isuzu bighorn starting issues
i think you must be check starter ring first,my experience to repair Isuzu truck, the stater ring was release from flywheel, not wonder but its could be happen.Try check first.
Jun 21, 2008 | 1999 Isuzu Trooper
BigHorn 4 Bike Carrier Logo
Top Yakima Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Yakima Vehicle Part and Accessory Expert? Answer questions, earn points and help others
