if the routor is wireless then the key is on the bottom or side of router. the ip address should be on it too and pass key to change the settings on the routher
there is a button on the bt hub with the wireless sign on it, press it to allow the usb device to connect. You onlt need to to do this once its a security measure to stop anyone logging into your wireless network. Also it will only stay allowable for connections for a short period of time. But as i have said you only need to do it once to allow the new computer to connect.
i need to know voltage and apms for the charger of the just blue wireless BT-10K, your should use the same, could you email me the info at [email protected] please. it would be of great help.
Thanx alot, steve
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on [email protected] should you need more info.
You can't use wireless adapter to hook printer to wireless network. You need a wireless print server. Example is Linksys or DLink Wireless-G PrintServer.
Go into your device manager and check and see if the usb connections are active and not turned off. If thats all ok open your network connections and make sure you see a wireless adapter there you should see two connections there, one should be lan adaper, and two should be wireless adapter. If not I need a little more info. Just write back to this sight and give more info what operating system your have wireless card ect. anything that will help, I hope this helps you out, usually you can fix it a couple differant ways you can email me anytime for more info.
