Inner small burner on dual burner does not heat well unless on HI. When tested on medium heat, the small burner continually cycles on for two seconds and off for 20-25 seconds. Water only simmers, never a full boil due to the 20-25 second delay. Repair did not test any parts and only said nothing is wrong with the element since it is heating.
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
