Sony Cyber-shot  DSC-W55 Digital Camera Logo
Adham Yassin Posted on Nov 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuse location i want to replace the lcd fuse but i don't know where is't
Harrie
Level 3:
Top Expert:
  • Sony Master 6,746 Answers
  • Posted on Nov 15, 2013
 Harrie
Sony Master
Level 3:
Top Expert:
Answers
6746
Questions
0
Helped
1284451
Points
83153
Are you sure your display is not working?
Did you try to view pictures you already made? in the viewing mode you can't switch off the screen. While taking pictures you can. For display mode look at page 16 of the manual.
It would be strange if there was a fuse for the display. It would be very strange if you could replace a fuse.
Link to manual Sony Cyber shot W35
Power steering fuse needs to be replaced, know what kind of fuse don't know where it is located have throughly check manual and car
on the door/lid of the fuse box there is a numbered or labeled diagram shows what fuse goes where and what amp it is
I need to know what fuse is for the power side mirrors for a pontiac aztek
Without knowing the year of your Aztek, I can only take a stab with what I know about the 2001.
This vehicle has two fuse & relay centers, the first one is located in the engine compartment, on top of the windshield washer fluid reservoir (you don't want this one for the problem you described).
The second one is located inside the passenger area of the vehicle, behind the center console, to the right of the gear shift lever.
Locate the removable access panel and give it a good yank to expose the fuse panel.
3_27_2012_7_05_49_pm.gifNow locate and check the fuses in slots # 16 and 17 (one of these should be your culprit).
After you have replaced the fuse (with a fuse of the same amperage) place the access panel onto the opening and give it a whack with the **** of you fist or a rubber mallet.
I hope this helps,Danno
Fuse
Hello!
Why do you want to replace fuse? Is your projector dead? In many cases just a fuse replacement will not solve the problem. if fuse is blown, good chance, that power supply has shorted components. still, you may try to replace the fuse with lower grade, first, and observe the behavior. If unit turns on and starts operate normally, then fuse blows, you may install the stock fuse. Means: it's just a fuse's issue. If it blows right away, don't even try to put regular fuse, instead. unit must be repaired, first. Power supply or ballast might be shorted. To locate a fuse, you must look around the unit and find a little door, says: fuse. it might have a screw or two holding it, might not. Look at the fuse, first: if it looks pulverized, don't even dare to replace it! it will blow again and make more damage to the unit. If thin wire inside is just torn, then follow the procedure, described above. If the fuse is ceramic, you won't be able to determine, how it blew. Look at the fuse's rating: it might be written on a fuse door, or on the fuse, itself. could be from 5amp to 10amp, depend on power consumption. Remember: first, install the fuse with 1/2 of value: i.e: 6amp-put 3amp first, etc. Good luck with your project.
Thanks,
Alex.
Cigarette lighter/acc outlet for 2003 chevy malibu not working. Figure it's a fuse - where is this fuse located in the fuse box? I know where the boxes are just can not find that particular fuse.
It may be doubled up with either the radio fuse or the interior lights. If you have replaced the stock radio with a CD player, then the CD player has its own fuse separate of the fuse box. I would start there...
2answers
All fuses taken from passenger compartment fuse box. need to replace them. don't know voltage or location,or what for it is used.
I'm not sure what the Make/Model of your vehicle is, I would suggest trying https://www.fleet.ford.com/maintenance/owners_manuals/default.asp to download the owners manual if you do not have one. it will have a fuse panel diagram you can use to replace the missing fuses. Hope this helps =)
There is a failure in the circuit of the heated oxygen sensor-bank 1 sensor 2. I don't know how to check the fuse since I don't know where it is located.
If you're getting a code for a heated oxygen sensor circuit problem, replace the sensor. I don't think I've ever seen a fuse be the problem. Bank 1 is located at the back of the engine compartment, close to the firewall. Sensor 2 is the sensor after the catalytic converter.
1987 vw cabriolet won't turn over, I replaced the starter and it's still not turning over my battery is fine and i don't know what to do:(
search for the IGNITION FUSE inside your fuse box, located below your dashboard. replace the fuse (make sure to use the recommended fuse rating).
3helpful
2answers
I have a 2008 gmc acacia. The front and mid auxiliary power outlets don't work. The fuse box is on a horrible location. I can't figure out which fuse it is and I don't want to spend hours...
{: ) At the underhood fuseblock, the AUX PWR fuse 20amps is for the Instrument panel and center console outlets, while the RR APO fuse 20amps is for the rear console and rear power outlets.
If your vehicle is equipped with an accessory 110vac, there is this PWR OUTLET fuse 25amps also at the underhood fuseblock. See red arrows on the sample diagram below:
wyet_helps_12.gif Safety reminders: Use only fuses of the same specifications. A higher fuse rating replacement can heat the wirings and could cause fire.
1helpful
Where is the truck lighter fuse located in a 1998 Durango
I don't know where the fuse for the "truck lighter" is, but the fuse for the "Cigar Lighter" is located in the Junction Block. It is fuse #15. It is a 15 Amp (Blue) fuse. The junction block is located in the left end of the dash.
I can`t find the fuse for the dashboard lights on my 2000 jetta.
First, make sure it's not that your dimmer switch has been turned all the way down.
Check fuse 22 and 23. If they're good then you may have a bad ground somewhere. Check the board and fuse box under the battery (yes, I know - but thats where vw located it) for corrosion.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
