This indicates a Service Call Error. Turn printer OFF, wait a few
seconds and then the printer ON. If the alarm continues, perform a
factory reset:
1. Turn the printer OFF.
2. Check that the front cover is closed.
3. Turn ON the power switch while holding down the GO button.
4. Check the Toner/Drum/Paper LED#s are lit.
5. Release the GO button and check that all LED#s are off.
6. Press the GO button eight times.
7. The printer settings will be reset to factory default.
8. The printer will then initialize and return to Ready status.
If the problem continues and the printer has a one year limited exchange
warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service
Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
Came home and there had been a power failure. Now, all lights are flashing and the fan stays on. I followed the steps described here, but it's not fixing the problem. Help!
Start with the headset powered on. Press and hold down
the call control button while also rotating the multi function dial
upward (away from the light) until the indicator light on the headset
starts flashing red then green. When prompted for passkey, enter
0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter
(discontinued): Turn the headset on and the adapter off. On the headset
push in and hold the mute/volume dial until the indicator light begins
to flash. On the adapter press and hold the blue power button for 10
seconds. The light on the adapter will flash once after 3 seconds-
continue to hold the power button for another-7 seconds until the
light flashes red. If the pairing is successful, the headset will
sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued):
If you remove the battery cover from the headset and then remove the
battery itself. On the Green PC board itself there will be a letter
followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
this is a new printer and all lights flashing..I have no solution
