SOURCE: hp 2355 all in one error message
mine HP was acting the same way after a jam. I contacted hp and they told me it was a hardware issue and that I would need to purchase a new printer. I found a KB on thier site for this issue. It involved removing both ink carts and then reseting the printer with the ink carts out. it seemed to work.
SOURCE: hp 5550 laserjet paper jam
Thhis error is usually due to a dirty photcell (sensor) in the tray 2 paper feed assembly or a broken sensor flag in the same assembly. Start be removing all cartridges and the transfer belt. Look in the bottom of the printer below the lowest cartridge slot for a removeable cover. That's the area your problem is probably in. I have incuded a link to a free PDF of complete service manual below. Good luck.
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%205500-5550.pdf
SOURCE: hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
SOURCE: Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
SOURCE: HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
