When I try to print, the orange "resume" light comes on along with a message telling me that the waste ink absorber is almost full. What do I do? The back of the photos I am printing have black ink lines. Is this something to do with the waste ink absorber?
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps ... Cheers :)
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
SOURCE: Ink wast absorber almost full
Hi there
There no easy way the printers are been made this way so you take them to the shop, but if you are handy with your hands and know what you are doing then you will need to take all apart and take out the ink pads inside the printer and clean them up make sure they nice dry when put back in, then you are going to need a program that you can find on the internet it will be called waste reset tools, or your printer will not work even after you done the clean out.
I have got canon MP-Tools on my website if this is the one you need.
with this you can reset the waste ink tank before you do the clean out but remember in time you will need to clean out or it going to be a big mess of ink coming out your printer.
Click Link = http://www.4all2sell.com/reset-tools/MPTool.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Testimonial: "I took my Printer into a shop but I think he's in over his head on this one. I'll get him to connect to your site. Thank for the heads up. Jim T"
SOURCE: Waste ink absorber
hi i am a certiffied Canon repair tech for this model. this is true this will reset the error but doing so without replacing the waste asorber pad in the bottom of the machine will cause your machine to backup waste ink into the the printing area of the machine and will start smuging ink on the page. the waste absorber is fairly cheap but the labor varies from shop to shop. there are independent Canon repair shops throughout the world. you can call 1-800-ok- canon or look on the canon website. hope this help to clairify.
SOURCE: Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true
with many Canon Ink Jet Printers: Eventually, you'll get an error
message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center".
Canon is totally sly about this, and is actually a pretty ridiculous
design flaw that they should be ashamed of- planned obsolescence.
Anyway, don't let this problem discourage buying an otherwise fantastic
Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK
IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any
case, your computer printer software will also tell you exactly what is
going on.
You need to do this after you get the WASTE TANK ALMOST
FULL message and the printer continues to work, but BEFORE the WASTE
TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The
waste ink take is actually just a felt pad that sits under the printer
mechanism inside the case and absorbs the ink from your cleanings. From
what I gather, its both a time consuming and expensive proposition to
take to Canon to fix. And they won't tell people how to do it
themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But
when it does, there is a fix-it-yourself solution that is both safe and
effective for the printer, and free. You have to be slightly mechanical
to do this. If you get this message and you've never used a screwdriver
and are all thumbs, well, Canon gotcha. But give it a shot even then,
or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In
some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset
code will not work. This was true of the S900 and i960 so, remove the
print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For
other codes for other printers and more info go here to this big forum
(but try the above first) Fix Your Own Printer Generally many of
Canon's models use exactly this same code, the i models use the same
code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
SOURCE: Waste ink absorber on canon iP 1600
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
