SOURCE: Intel graphics media driver update wiped out my
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
SOURCE: Lenovo G480 cant adjust screen brightness! please help
On AC or Battery? As I'm sure you know, your Laptop will dim the Display on Battery to save power. In Windows 7, Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, set Display time, set Sleep and Hibernate to Never, select Change Advanced Power settings, scroll through each one by one and adjust. OR right click a open spot on the Desktop, select Personalize, left bottom select Display. adjust to your preference.
