Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB Bottom Freezer Refrigerator Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control board reset?
Our Amana freezer on the bottom refrigerator is keeping the freezer too cold and the frige not cold enough. Repair guy out last week and he thinks we need a new control board. (This would be second we've installed-unit is only 3 years old.) Is there a way to reset the control board or test it some how?
  • Anonymous May 12, 2009
    I used the 5X switch and it worked - the vents at the rear of the freezer defrosted and the refrig temp went back to normal.
    I wasn't sure if it needed to be reset to "run", so I did the 5X switch again. Did I just put it back into defrost or reset it to run?
    Could it have been a one time problem or will it freeze up again?
Robert Moller
Level 3:
Guru:
  • Master 1,524 Answers
  • Posted on May 04, 2009
Robert Moller
Master
Level 3:
Guru:
Answers
1524
Questions
Helped
579982
Points
4327
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
monika marriott
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 06, 2014
monika marriott
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1527
Points
My top refrigerator not stay cold both freezer is fine
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
1helpful
Refrigerator and freezer not coming up to temperature. replaced start device on compressor what else could be the issue
Some of these brand friges have a tendency to not defrost the freezer side properly. Ice builds up behind the freezer panel thus reducing air flow to the frig side. Having replaced all parts repeatedly on my WP frig, actually two of them, and losing food repeatedly, a WP repair guy said it was unrepairable. WP is crap. Their design is crap. Many side by sides are littered with cooling problems. The defroster coil, defrost sensor, and thermostat just dont work properly. In the end, I bought a diff. brand and will never buy wp again. Keep in mind how many brands are sister brands to wp and avoid them too.
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
2answers
Amana model AB1924DEW freezer is too cold, but refrigerator is not cold enough. Have adjusted controls with no effect
There is a door that allows the air from the freezer to cool the fridge side. Sometimes these are manual or mechanical. It may need stuck or repair depending on what you have. If you look in the back or or fridge at the top there is probably a opening for that air to go through. Maybe it is plugged from ice, you may have to look around if the freezer is on the bottom. It could be numerous problem. Rule out the most obvious first and go from there.
3helpful
I have a model ARB2257CSR Amana frige (freezer on bottom) and the freezer is not working I think. there is a sound that comes on and off like the motor maybe is trying to come on... the sound comes from...
Sounds like the overload/relay is going out . If the noise is a " click " , replace the o/relay after checking the 3 terminals on compressor for continuity and each terminal to ground ( copper tubing ) .
2helpful
Refrigerator cold but not cold enough. freezer
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Frige freezing solid
1helpful
2answers
Fridge problems - frigidaire
Sort of sounds like the adaptive defrost board is bad and you are not going into a defrost cycle. Do you have ice build up on the lower interior freezer section? Are the vent slots full of frost/ice? Ideally, pull the freezer shelfs out and take the little aluminum panel off the interior back to look at the coils. Are they basically a block of ice and frost? The problem happens when the unit doesn't go into defrost cycle and the coils freeze up. That blocks the air flow in the freezer so you get frozen food at the bottom but soft stuff at the top. And the frige just can't get enough cool/cold air from the freezer section to cool anymore. Power surges or blackouts, etc. can just destroy the defrost circuit board. Without good air flow the unit is not going to cool properly.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
