I appreciate your inquiry, stephen couch!
From the information you have provided the lights on and inside of your freezer are off and your compressor is running. This sounds like a possible short within your control panel or wiring issue. I see you have performed a reset on your freezer by unplugging it and plugging it back in. Typically, to perform a factory reset we would suggest unplugging your freezer for roughly ten minutes. If that does not help I would suggest having a professional come out and perform an accurate diagnosis. This will help avoid any unnecessary part purchases. Best of luck! -Matt
condenser has been clean, fan is running below, also when stops running only freezer fan runs. unplug for awhile then plug back in,then compressor starts only for a few days. then I repeat process
compressor is hot could it be overheating, if so what would cause this. Is something overloading it. Could it be relay switch
Thank you so much for your feedback. I will have to call repair man to see exactly. Feeling sense of relief that may not be compressor. Take care
When this happens, feel the compressor.
Sounds like it is overheating. Condenser clean, fan running (if so equipped)
