The ringing/dinging only started last friday, so its not when i put the key in it. Its a fast ringing and when i take the key out it does it for like 45 seconds
I solved this problem by booting into SAFE MODE on the G1:
Press Menu Button and Switch on the G1 Phone using Power button. (Do not release menu Key).
That Got it to turn on. but upon power down it did the same thing with blue light. So I always start in SAFE MODE. I will start uninstalling programs until i find out which one is causing problem.
Try disconnecting the battery cable for a few minutes. This may clear the security code and allow the normal key to operate. The sensor in your tire may have gotten damaged when it was repaired (this is not uncommon). The solution, take it to a tire store, they can change the sensor if needed.
hit f8 at startup, choose enable VGA mode. After boot, download the new driver for the ati video card and install it. You can go to the hp website and download the video driver there.
I had the same problem with my NES only my screen was Pink. I just get a very light damp cu tip and cleaned the trids on the cardriges or the expansion pack, maybe have dust in the insertion where the trids fit in, or on the trids. you could also blow air into the insertion port.
