Sharp 27U-F510 27" TV Logo
Posted on Aug 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setup will not connect to uhf stations using rabbit ears antenna1
When I go to set up, conect to antenna or cable [i do not have cable, but an fm-vhf-uhf anntenna. I do not have the manual to trouble shoot. When I do ch settling ez set up for anntenna or cable, it only memorize when vhf channel and while going through auto programming seem to go over other channels but not retained and some are not even shown. I have re-run set up numerous times.
richie46
Level 3:
Top Expert:
  • Sharp Master 12,962 Answers
  • Posted on Aug 21, 2017
richie46
Sharp Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941693
Points
58151
Signal is not strong enough. Use outdoor aerial for best results.
4 Related Answers
Anonymous
  • 398 Answers
  • Posted on Sep 01, 2007
SOURCE: reception of vhf/uhf channels
You did not mention which set you have, so look for a small switch (usually on the back of the set) or go into the menu and set the TV to the "broadcast" or "tv" mode. If the set is in the "cable" mode, you will not get any UHF channels above 13.
Anonymous
  • Posted on Dec 21, 2008
SOURCE: Channel keeps changing to 'Input 2' even when playing DVD
Have you taken the remote control out of the room? Try changing inputs from the TV.
Anonymous
  • Posted on May 06, 2010
SOURCE: Not to switch from air setting to cable setting
hola tengo una tv pero no puedo prgramarla para mi cable de tv los canales se ven brumosos como le puedo hacer gracias
manigordo
  • Posted on Mar 15, 2011
SOURCE: use following steps to reset
img{-moz-force-broken-image-icon:1;} Same no sound issue happened to me; except I stopped at adjusting vertical size (unfortunately it seems horizontal cannot be set thru service mode; which was my original intent). Complete lost of sound signal processing; oddly enough speaker volume leveling did worked. (Eg, audio-in woks; so a big WTF?!) I suspect something to do with not recovering properly the data bus from muxing the volume input keys; ie, some kind of weird service/back-to-normal switch bug. I've waited for a couple of days for the damn thing to unlock itself out it (like some stubborn transistors seem to do); but to no avail. (BTW, only dif between TVs is that mine's a slightly smaller and cheaper model, a 19U-M100S; a minor branch out of the main line.) I'm afraid something did "burned out" and that the only real fix is to actually change the "defective" part. Had I known silly sh1t like that could happen, I obv would've not messed with it to begin with. It's just ridiculous, and lame. Besides being obsolete. In any case; I also think it's nowadays better to get a (full) digital one (wisely cost effective).
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
I live in Victoria Tx. I can not afford cable or dish. I am able to recieve all 4 of the the number 25 channels. Why am I not able to recieve any of the three number 19 channes. All 19 and 25...
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
2helpful
TV picture freezing
digital signals do not fade out and get snowy like signals used to do ... if the signal gets too weak then it just freezes .. you might say its either perfect or frozen .. sometimes it gets blocky .. where some sections of the screen freeze while other sections continue .. what that means if you are using an antenna is .. you need a better antenna or better aim for the one you have .. outside is much better than inside but just rabbit ears are ok for strong signal areas .. you can aim the antenna based on a signal strength meter usually provided in HD receivers in the setup menu .. you can also get an antenna map from "www.antennaweb.org" .. that will show you what direction to point the thing for each channel and how strong each channel should be ... if you are using Cable instead of an antenna then you should have good signal strength but there is a problem called "Crest Factor" .. that becomes an issue when they put too many signals on a given cable .. the cable handles it ok as long as there is no damage (bad ends, water inside, animal chews, corrosion) but the cable box or receiver may be overloaded as thousands of signals drift in and out of phase ... thats a cable company problem that might be getting worse as more channels are added .. the results are that periodically the picture will freeze or pixelate .. you probably have to accept a little of that but more than a little gets really irritating ....off the air reception with an inside antenna (like rabbit ears) you will find that moving around the room can effect the signal for channels in the UHF range (most are) .. aiming the antenna and getting it as high as possible will minimize that problem.. make sure whatever antenna you use is designed for UHF as well as VHF .. the little circle often found between the two "rabbit ears" is actually the UHF part of the antenna .. it can be rotated for UHF channels while the big ears are aimed and adjusted for VHF .. antennaweb.org will tell you which is UHF and VHF ..
Local ABC and PBS stations do not come in. All others local stat
Check to make sure your DTV antenna is an "all band" antenna with reception in both the UHF and VHF bands. It sounds like you may be in Philadelphia area. In Philadelphia, all the DTV stations are in the UHF band except Ch 6 and Ch12, which are in the VHF band. Some of the DTV antennas are UHF only. You can tell if yours can receive VHF if it has the "rabbit ears" long wip antennas. If so make sure the whips are extended fully and turn the antenna to try to get a good signal.
Visit the 6ABC and WHYY websites for up to the minute information about the issues with reception issues.
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
2helpful
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
3helpful
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
No HD
Your TV has a built in tuner but NOT a built in antenna. Depending on where you live (distance from broadcasters) you will need to add anywhere from rabbit ears (with the UHF loop) to an antenna on the roof or mast.
If your home already has an antenna installed, connect the coaxial cable to the back of your TV. Then go to "Set-up" and scan for DIGITAL channels. If you are trying rabbit ears, do the same.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
