magicjack.com Logo
j
jay anderson Posted on Nov 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a card for conference calls. where can i get one and for how much.
stephen Adams
Level 3:
  • magicjack.com Master 2,219 Answers
  • Posted on Feb 04, 2015
stephen Adams
Level 3:
Answers
2219
Questions
0
Helped
355155
Points
22262
Conference calls can be made for free.
To set up a conference call:
  1. Dial 305 848 8888
  2. Select "Set up a Conference Call" and follow the prompts.
You will create a password and will be given a 10 digit code.
Distribute the code, time of call, and dial in number (305 848 8888) to all conference call attendees. You may use the access code for any future conference calls as well.
To join a conference call:
  1. Dial 305-848-8888
  2. Select "Join a Conference Call"
  3. Enter the pin
2answers
What are the best conference calling services in India?
Conference calling is required in any company with a branch located either domestically or internationally. It's quite normal to get on the conference calling with teams from other branches, partner firms, or even clients on a weekly basis. A good conference call service is the one that understands your company's requirements and acts on it diligently to provide crystal clear call quality and also offers you flexible payment plans.
On top of the calling facility, a conference call equipment needs to have some very essential features, some of which include- mute/un-mute, local dial-in number, anytime conference, start without host, chairperson dial control, roll call security, chairperson or guest PIN security, etc.
Such a calling facility in India is provided by Reliance MindBridge which is the leader in telecommunication in the country and offers fantastic deals for businesses needing conference call service to 230 countries and territories all over the world.
1helpful
How do we arrange a conference call?
While on a call, press conference or transfer button(will put first call on temporary hold). Make call to next party, talk to party, press conference button to join all callers. Same procedure to add more parties up to 8 total.
Also, if you use transfer button to start conference call you can use transfer button to join all parties.
If you use conference button to start conference call use conference button to join all parties.
How do I start a conference call on a Mitel 5303 Conference Phone? It states it only hosts up to 8-10 people.
I'm assuming you are using this on a 3300 ICP. In that case, the phone system is only able to do 8 party conference calls without an external Conference server.
You can dial the first number, press the flash button, dial the next number, dial the feature code (get from your vendor), repeat until you have all parties as part of the call.
The 5310 IP conference unit works much easier than this phone. A conference bridge such as Audio Web Conference with the appropriate licensing will allow for extended conference calls... it will also allow you to record the call for later "off-air" participation.
3helpful
Three party conference call
Once you receive your first call Press conference button. your first call will automaticaly be on hold. Press a line button to dial second number. Once call is connected Press conference button and you will have 3 way conference.
To add more PeoPle into conference Press conference button again and select a new line. Dial the number and Press conference button to connect everyone to that conference.
HoPe this helPs
2answers
How do I conference call on a Polycom Voicestation 400?
Conference call is not a feature of the phone, but a feature of the telephone system in the company. Usually you press a sequence of keys like flash #02 to trigger this function in the phone system. If your company phone system does not offer the feature then you have to use an external conference call provider.
HOW TO DO A CONFERENCE CALL
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
1. Make or answer the first call.
2. Put the first call on hold.
3. Make or answer the second call.
4. After the second call is connected, press [Feature] [3].
5. Press the line or intercom button of the first held call.
6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
Unable to use conference button
Usin for an internet conference
You need to buy a Computer Calling Kit from Polycom. That is essentially a cable with a 2.5mm connector to the Polycom Soundstation 2W on one end and two 3.5 mm connectors to the PC Sound card end (one to the Microphone port and the other to the Speakers port).
Polycom sound station 2 conference set conference problem
sounds strange, it lookslike a main board problem, considering that u have been using similar unit before.there is not much that u can do from the menu options.u will have to refer ur vendor for rpairs
Conference calls
this will be threw your service provider to set up more than a 3 way calling plan
3 way should be standard service with only 3 people at time anything extra needed the service provider can set up the extra 3 waying +
on the phone handset if your just looking for in home conference calling to others just click the conference button find the handset you want to talk too or all the handsets this is conference calling
Top magicjack.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a magicjack.com Computer and Internet Expert? Answer questions, earn points and help others
