I recently purchased this decode software for my business
and it seems to be doing very well. I ran your serial number and received a code of 5871. Would be grateful if you would let me know either way if this code worked as I want to keep track and make sure I got my money's worth buying this software. You can reply/comment here or email me directly at [email protected].
Thanks and I hope this works for you....
SOURCE: unlock code for stereo
I found a gal that will give you the code you are looking for. Give her the serial number and she will post the code, You will need to register on the site or I would have gotten the code for you. Here is the link: http://forum.gsmhosting.com/vbb/showthread.php?t=350260
SOURCE: radio code ford focus 4000rds
Your code is 6126
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate
SOURCE: I need a code for my Ford Fiesta radio. The radio
Unfortunately the short answer is NO..
You could try pressing 1 & 6 together ( and other combinations) but I`m fairly sure that the Serial Number is not available using the "press button" method on this model
The Serial Number usually begins with M++++++ and is found on a label on top of the radio casing so if you can access that somehow ( eg..via the glove compartment ) and using a mirror+torch then you may be able to see it.
The alternative is to see if this M++++++ is in any of the car`s paperwork somewhere.
Failing that , then I`d take it into a Car Audio Store and get them to try and extract it. (Try Halfords and chat one of the blokes up...it usually works for a lady.. )
I am very surprised that you say 3 genuine garages have tried without success as even the most stubborn units with damaged fittings come out eventually.
Perhaps Garage 1 (or someone before Garage 1 ) did not use the right extractors and has really damaged the spring fittings.
Testimonial: "Really helpful and clear!"
