Slow constant drips along entire bottom edge. totals @ 1 pt per load. new washers at both hose ends
SOURCE: Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
you have a bad water valve.. replace the valve where the hoses are hooked to your washer
SOURCE: washer leaking out water from the bottom
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
SOURCE: When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
SOURCE: Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
