I'm having the same problem as this person: http://androidforums.com/android-lounge/603252-random-freezing-app-crashing-straight-talk-zte-merit-z990g.html
My phone will only turn on to the blue Tracfone screen, then it continually makes the startup sound but won't advance any further.
If you hear a noise that means that the electronic solenoid is operating, so it isn't the fuse. You do have power going to it. It appears that it is a common issue. One way that often works is to have someone in the car and someone at the boot. The boot person presses down and on 3,2,1, the car person presses the button and the boot person jerks the boot up.
How were you notified that you had won a phone (a cell phone, I assume)?
The notice could have been a way to gather your personal information - a phishing scam.
If you do not recall entering any sort of "contest" to possibly win a phone, be very suspicious and do not reply to the message.
Your device may have been infected with malware. Any device you use (computer - laptop or desktop, tablet, cell phone) needs to be protected with up-to-date "anti-virus protection."
Read the information here: https://community.norton.com/en/forums/i-have-won-phone-pop-ups
Hi Try resetting it.But note that this will delete your personal data,downloads and third party applications on the phone restoring to its factory settings.
Start >Settings >System >Clear phone memory Follow the instructions.
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
I would try a boot without the SIM and if that does not work by itself, I would try toggling the volume bar on the right of the phone during boot, as that is supposed to give the hard reset option.
1.Some operation performed before the phone hang has corrupted your Phone start up data. Thats why your could not able to Boot 2.Remove the Battery or switch on/off one or two times. Check whether Boots this time. 3. Else Remove your Memory card from your phone. also Check Now your Boots up Normally. 4. If phone still persists with same Boot up problem. then one way is to Hard format the phone memory to get back all default settings. So as to make your phone Boot up Normal 5. Hard trick method can erase all your personal information such as Contacts, messages,Wallet data's,Phone Settings.Erase Gallery,Video data. 6.Before you continue this method. Try steps 2 and 3 7. if everything fails and still your phone could not Boot means 8. Press 3 & * & green dial button & switch on/off button Continously until you get Formating Screen. 9.I think your phone boots now. if not Contact service centre. they might flash your Operating system..
