SOURCE: nikon fg light meter
Ah, I figured this out. It's not the battery, since the light isn't dimmed. I had the same problem with the light being stuck at 60/120, and it was just flashing. There's a certain mechanism in the camera that only allows the light meter to start working when the exposure count is at 1. So when you load your film, you have to take 2 or 3 exposures, and crank it, before the light meter kicks in.
SOURCE: Nikon FG Shutter and light meter not working
Sorry, but there is nothing else you can do without dismantling the camera and giving it a full service. It's not a DIY job so will have to go to a repair specialist.
Note that unlike some similar Nikon models of the time, the FG's complex electronics mean that your camera may now only be good for spare parts as it's likely that the main circuit board has failed and replacements simply are not available and arevery difficult and expensive to fit if you're lucky enough to locate one. The reputation for failure of this model due to ageing circuitry means that it's now unpopular and near worthless.
A repair specialist can certainly tell you whether the camera is repairable before undertaking any serious work on it.
Personally, I'd just advise you to sell it as is for spares or repairs and to obtain a working example or even the mechanical Nikon FM/FM2 which are still plentiful, easily serviced and repaired, and available fairly cheaply or even free (via FreeCycle).
Testimonial: "Thanks Obertelli for taking the time for the detailed answer. I am hoping to keep the 50mm lens and hopefully use it with adapter."
SOURCE: My Nikon FG's light meter
Try new batteries, And make sure the frame counter is past one to get meter to work right.
