The UL code is at it again! We continually are shifting the load around to get them to finish. we are planning on taking the washer apart this weekend. could you give us a list in one place (their are many different ideas on this one website) of what we need to do / replace . looking for a simple step by step instructions, If possible.
SOURCE: Maytag Bravos top load gives LF code not working. Any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
SOURCE: How do you select the load size on the Maytag
You do not select a load size, the washer detects the load sizes, then uses the amount of water etc.
SOURCE: How do you replace the door latch on a top loading
IS THIS UNIT NEW YOU MITE WANT TO HAVE SOME FROM SERVICE DO THIS
SOURCE: Can I pack insulation around
NO!
(If you haven't already, try my guidance notes on leveling, please!)
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
