I keep getting a message to raise the presser foot even when its up. I opened the machine up and can't seem to figure out whats wrong but I am guessing that a small round piece that fell out might be part of the problem. ANy idea how I can figure out where it goes or know how to fix the presser foot issue?
SOURCE: parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
SOURCE: Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
SOURCE: Persistent E1 message
some machines have a presser foot sensor or switch which prevents the machine sewing if the foot is not down.
if your presser foot is down and you still cannot sew the switch or switch actuator is most likely damaged. you will require a tech to repair this.
scott
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.
