Computers & Internet Logo
Posted on May 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help with front panel cables connection, case to mainboard.
Any idea where I can find MSI-7191 MB manual as I can't work out the front panel cable set up (speaker, power switch etc) as there is very little info on the Motherboard itself. thanks
  • lanatk May 04, 2009
    Thanks! Much appreciated
Anonymous
Level 3:
President:
  • Master 1,179 Answers
  • Posted on May 04, 2009
Anonymous
Master
Level 3:
President:
Answers
1179
Questions
Helped
422675
Points
3751
The best place to look would be msi.com. Click on the support link and lookup your specific board model #. All drivers, and manuals should be available there for free download. Hope this helps.
1helpful
CONNECTING SEQUENCE OF PLUGS ON USB 1 AND USB 2 TO MOTHER BOARD
Hello you can download the manual here at MSI:
http://www.msi.com/product/mb/KM4M-V.html#/?div=Manual
You will need adobe reader, to read the content.
The manual should show you how to connect the cables to the mainboard.
If other files needed select in the download option.
Good luck
Power problam
Hello the manual can be downloaded here:
http://www.msi.com/product/mb/945GCM5.html#/?div=Manual
Please unzip the file when downloaded.
You will also need adobe reader to read the content.
Try to renew the power supply.
I think that`s why the mainboard is not having any power.
Look also for the front panel on off connector, is not connected wrong.
If no luck changeing the power supply, the mainboard probably has a internal fault, and must be renewed.
Good luck
Wiring diagram for ms 7069
Hello here is the homepage:
http://www.nec-computers.com/support2/pib.asp?mode=default&platform=platform_callisto_g_mt
This mainboard is a OEM manufactured by msi for NEC.
The support belongs to nec, and there is nothing to be found at the msi homepage.
Basicly its just to connect the 20 or 24 pin power connector, and the 4 pin atx power supply.
Next connect the power to the dvd and harddrive.
Then connect the data cable from the drives to the mainboard.
The front panel connector looks like this:
This is basicly the same for all msi mainboards.
Next you can power up the pc, and enter the bios and set the boot order ( press the delete button when posting )
Lay the windows disk in the dvd drive, and leave the bios and save your settings.
Now your ready to install windows.
The drivers can be downloaded here:
http://www.nec-computers.com/support2/pib.asp?platform=platform_callisto_g_mt&mode=2000&title=Downloads
Best of luck
3answers
I don't know which wires to connect and to which slot it should be connected
The most important cables only FIT one plug. If it fits in one but will not fit in ANY others. Thats probably where it goes.
If you need to know which wires for your case such as front usb slots try this pinout diagram
http://image.pinout.net/pinout_files/standard-usb-pinout.gif
Otherwise you will need to be more specific.
MS 7191 not powering up. replaced power supply and still not working. pull the cable from the front panel and now can't plug them back because indications are not clear on the board.
Does the processor fan come on? If so you need to replace motherboard. If fan does not come on need to verify that all connectors are correct and let me know.
2helpful
How do I attach the front USB, speaker and mic of the case to MB?
Follow that arrows on the pictures. Plug the USB Front Panel Cable.
5helpful
6answers
Product manual
Link
At the bottom of the page is the heading, Manual
under that is the link to the download, click on the down arrow.
MSI 915o comboAudio front panel
Some cases come with a Mic & speaker jack/ cable. These jacks sit within the case. Rather than using the rear Mic which is (colored pink) & speaker (colored green). These 2 colored cables run from the front of the case & out through an emty hole in the back of the case. Which you connect them to the rear of the boards Mic in (pink) & sound (green). Now you can use your front audio jacks for both mic & sound. This may sound strange but I have come across many cases just like this. Its not uncommon to have 2 front usbs & a 1394 connect on to the board as well. Without your manual I'm sorry I can not help you fauther.
1helpful
Front USB and MIc connectors on KT6 Delta MS-6590-Ver2
If you go to the link below, you can download the relevent manual for your motherboard http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=557
Grand Canyon Tech
Grand Canyon Tech
