LG LFC23760SB Side by Side Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Nov 13, 2013
Wheel on track fell off when drawer insert removed
Anyone have a fix for the full-length deli drawer constantly falling down? Maytag 20.5 cu. ft. Black Ice Top-Freezer Refrigerator Model Number: MRT311FFFE
I would remove the track, clean both surfaces and stick it with clear silicone or superglue Gel. Leave it 24 hours to set.
How to insert a freezer drawer
Try lifting up on the drawer while trying to insert the drawer in the track
Mar 13, 2013 • Freezers
Top drawer seems to off track, tough to close, etc
check to see if wheel rollers are broken . Or off track . Then if off track allign it .
1helpful
1993 Jeep Grand Cherokee. Passenger window fell (tipped forward
All its done its just come off its tracks so remove the door insert carefully place the window back on the track and tighten it up using basic tools and no the door insert/panel can come off even if the window is all the way up. Hope this helps.
1helpful
2answers
Desk drawer: can't full close drawer'' waterloo bearing glides
Just a guess, try pulling the track out of the box,onto the drawer
1helpful
Drawer beneath oven keeps falling off it's little wheels
I sympathise with your problem and sorry about your broken toe.. The drawer sits in a slide and the rollers on the drawer travel inside the track.. If your husband is reasonable handy ( or you ) ..empty the drawer and try to get the wheels into the track on the oven.. this process is similar to that used on some kuchen cabinet drawers and furniture so it is no different..just hard to see or get it started..
With the drawer out of the oven..use a flashlight and examine the track to make sure it is not damaged ( do the same thing on the mating slide/rollers of the drawer)..
If possible, can you return to the place you bought it from and have them show you how to do it? They owe you at least that much... Good luck and take care of that toe...
1helpful
Maytag Oven model MES5752BAW when using the bottom drawer it works hard to close and goes off track and one side is higher than the other. Please help on how to fix this problem this oven was bought Aug....
remove drawer entirely. and one side at a time try reinstalling the rear wheel over he fixed (mounted wheel on unit. one side at atime with drawer empty, always easier.its gonna take some fiddling but it'll go. if it falls off track regularly then its possible that the lower frame of unit has bent and might need a little "persuasion" to line up correctly
2answers
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
1helpful
Drawer came off track
You need to open it, lift two tabs at the back of the tray on each side to allow you to remove it, then re-insert making sure it's back on the rails.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
