Life Fitness Lifefitness 9100 Hr Treadmill Cardio Functional Health Logo
Christian Beccar Posted on Nov 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When running get error message your pressing on the board too hard?
ernesto cuadra
Level 3:
Top Expert:
  • Life Fitness Master 12,223 Answers
  • Posted on Nov 14, 2013
ernesto cuadra
Life Fitness Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081119
Points
34431
RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
God bless you
4helpful
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
5helpful
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    1helpful
    I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
    This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
    Full instructions on removing and replacing the hard drive can be found here:
    http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
    I have a dell inspiron E1405 laptop. when i am not using it for half an hour after opening it it is going into the following error: error code: 0148 message error code: 2000-0148 message unit:...
    Go to
    http://support.dell.com/support/0148
    For further support as you have a hard drive error.
    Hope this helps.
    How to run PSA Diagnostics
    Article Summary: Instructions on how to run the PSA Diagnostics, and an Error Code list with possible solutions. Table of Contents:
    1. Start the PSA Diagnostics
    2. Error Code List
    Step 1: Start the PSA Diagnostics
    1. Restart the system.
    2. At the Dell logo screen, press <F12>.
    3. new_note.jpg Note: Some systems do not have an F12 key, to access the boot options you have to press the <0> (zero) key at the Dell logo screen.
    4. At the One Time Boot menu, press the <Down> arrow key to highlight Diagnostics, then press <Enter> to begin PSA.
    5. Write down any error codes listed.
    6. Use the list provided in the next section to see what the error code means.
    Instructions For Fixing Hard Disk Errors
    Click Start
    Click Run
    Type CMD
    Press Enter
    Type CHKDSK q: /F
    where 'q:' is the drive-letter assigned by Windows to your Samsung.
    Press Enter
    If you get a message about "disk is locked - delay disk-check until next reboot", click OK, and shutdown/reboot Windows.
    When "check-disk" has finished, any correctable errors will have been corrected.
    17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • 3helpful
    2answers
    Latitude delld610 Boots with the following
    press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
    System boot problem
    This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
    A disk read error has occured press CTRL-ALT-DELETE to restart.
    check power chord or port of hard drive if u dont find any prob. pleace re insert power cord with card board packing. definetly u solve the problem.
    I have asus m2n-e board, i used 80 gb hard drive in sata 1 socket, used 4 hard disk of 250GB in from 2-5 ports and used 320 gb hard disk in port 6, configured 4 250gb hard disks in raid 5 using the mother...
    USE DIFFERENT PORT FOR PROBLEM OCCURED HARD DRIVE AND CHECK SAME PROBLEM CONING TO THAT PORT ALSO .THEN THE PROBLEM IS WITH YOUR HARD DRIVE .REPLACE IT.
    Top Life Fitness Exercise & Fitness Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Mike Cairns
    Mike Cairns
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
