For parts specific to a type of faucet, you normally need to go through the manufacturer themselves or through a plumbing suppply who will do that for you sometimes. I would call Elkay
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
You need to turn the water off under the sink. Disconnect the sprayer hose from the threaded shank under the center of the faucet body. Pull the spray head out of the faucet. Contact Blanco to receive your faucet parts free.
The flex hose for the sprayer can be seen under the sink. It may be hung up on a pipe or other object.
As long as there is nothing broken on the sprayer you should be able to ease it back into place by gently applying a "pulling" pressure on the sprayer hose under the sink.
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
Here are the instructions:
Turn off water to faucet.
Remove handle.
Remove top cap.
Turning spout back and forth gently lift and remove.
