Have a NordicTrack C2150 Treadmill - about 2 years old. Has worked OK, except I never liked how often it always needed to download firmware updates in the past (slow internet connection means no workout that day). A couple days agon, when turned on, the normal console screen with the "Start" button in the middle and 'Map, Train, Compete, Track, etc.' buttons along the bottom, no longer come up. All that screen shows now is some kind of 'Android interface screen' with a couple menu navigation buttons on the right hand sight. None of the settings or options I've tried to navigate to or select have helped. None of the main buttons on the Treadmill itself (Start, Incline/Decline, Speed, etc) are responsive either. I've tried an on/off warm re-boot, and a complete unplug and re-plug five minutes later cold boot.
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
sincerely. Please keep me in touch.
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
